  • July 16, 2025, 08:01:53 AM
Author Topic: Red Putty?  (Read 2076 times)
Red Putty?
« on: August 06, 2014, 07:53:18 PM »
What is that red putty I see on planes when it is getting towards the end of finishing? Is it Bondo type putty? Must be sand able.
Thanks for any clarification.
Offline RC Storick
Re: Red Putty?
« Reply #1 on: August 06, 2014, 08:21:27 PM »
No good! Don't use it! Use the putty I mention in my finishing videos if you have to spot anything. They call it red lead for a reason.
Re: Red Putty?
« Reply #2 on: August 06, 2014, 08:46:47 PM »
 Yep, it's Bondo.
 I'll use it occasionally, but only for small imperfections where I'll be sanding 99% of it back off. Like Sparky says it's known as "red lead" in the C/L world, it gets heavy quickly in larger amounts.
Re: Red Putty?
« Reply #3 on: August 07, 2014, 07:18:20 AM »
Thanks fellers......that helps a ton.
Re: Red Putty?
« Reply #4 on: August 10, 2014, 06:04:34 PM »
Now there's a pun that can be clearly coated without any runs or fuzzies.  y1 Steve
Offline 55chevr
Re: Red Putty?
« Reply #5 on: August 10, 2014, 08:20:51 PM »
Red putty is an automobile finishing glazing filler.  I use Nitro Stan 9001 on cars, it has been around since Model A-s were a new body style.  In the old days it was called red lead and for good reason.  It is designed to fill scratches and small imperfections.  It doesn't have any structural integrity.
Joe Daly
