  • August 03, 2025, 08:39:00 PM
Author Topic: Rattle can white  (Read 1793 times)
Offline Vincent Judd
Rattle can white
« on: May 11, 2018, 06:50:07 PM »
We all know that all whites are not created equal.
What is the whitest white I can get out of a rattle can paint?  I'm trying to match a Monokote white, which seems to be very white.
I tried something called Duplicolor Bright White and was very disappointed with the color.  Not even close.
Appreciate any suggestions.
Vince
Offline Bootlegger
Re: Rattle can white
« Reply #1 on: May 12, 2018, 11:29:19 AM »
  Try Walmart, they have a lot of spray paint, and maybe they have a color that will match..
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #2 on: May 12, 2018, 12:48:13 PM »
I seem to remember using Krylon white once that matched up very well.  That was several years ago, so who knows now.
Offline Charles Meeks
« Reply #3 on: May 12, 2018, 01:17:47 PM »
I love the Rust-oleum professional high performance enamel.   I have used it on a couple of products and it is GREAT!  It dries fast and hard almost like epoxy paint and the color is a very bright white.
Charles Meeks
Abita Springs, LA
Baton Rouge Bi-Liners
AMA # 988201
Online bob whitney
« Reply #4 on: May 12, 2018, 07:02:59 PM »
look for refrigerator white
rad racer
Offline Skip Chernoff
« Reply #5 on: May 15, 2018, 06:25:58 PM »
Vince, Rustoleum Protective Gloss Enamel white is very very close to white Monokoke.See the photos of my Shark 45. Rustoleum on fuse,monokote on wings......Skip
« Reply #6 on: May 17, 2018, 07:39:45 AM »
Thanks Charles, Skip, going to give the Rustoleum paint a try.  Searched on line and found some at a Walmart nearby.  $15 on line, $4.94 at Walmart.  Go figure.   I like the 15 minute drying time for the professional brand, I paint outdoors.  I'm all electric, so no worries about fuelproofiness.   LL~
« Reply #7 on: May 18, 2018, 05:41:43 PM »
Make sure it's Rustoleum Gloss Protective-  they make several different brand names for themselves that are cheaper, and other even cheaper ones for other brand names.
Shake the hell out of the can.  Maybe your local hardware store will shake it for you, and warm the can over 100 degrees for better leveling.
