Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 16, 2025, 03:52:36 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Paint and finishing
(Moderator:
RC Storick
Masking Tape
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Masking Tape (Read 3316 times)
Dan Bregar
24 supporter
Trade Count:
0
Captain
Field Marshall
Masking Tape
on:
April 03, 2011, 08:06:41 PM »
What is a good type of masking tape that is flexible for taping radii, curves and bends on stunt jobs ?
And where in the heck can I get some ?
Logged
AMA 33676
Clint Ormosen
2019 supporter
Trade Count:
0
Admiral
Re: Masking Tape
Reply #1 on:
April 03, 2011, 08:51:48 PM »
I use Scotch brand blue fine line for curves. The 1/8" works well.
Logged
PJ Rowland
AUS - 29541 AMA - 809970
Trade Count:
0
Admiral
Melbourne - AUSTRALIA
Re: Masking Tape
Reply #2 on:
April 04, 2011, 01:18:17 AM »
Yep Scotch blue fine.
I get mine from a car paint supplier.
Logged
Allan Perret
2017
Trade Count:
0
Admiral
Proverbs
Re: Masking Tape
Reply #3 on:
April 04, 2011, 07:22:52 AM »
http://www.finessepinstriping.com/
Logged
Allan Perret
AMA 302406
Slidell, Louisiana
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Re: Masking Tape
Reply #4 on:
April 04, 2011, 10:29:42 AM »
I use both Finesse "The Edge" tape and also 3M blue vinyl tape for taping off paint lines. I also use other stuff depending on what I'm trying to do. Really sharp turns are sometime better with a cut out from either vinyl or perhaps Frisket rather than trying to go around the corner with a tape, no matter how thin. I use the Finesse stuff in 1/16", 3/32" and 1/8" and occasionally use some 1/4" stuff again depending on what I'm doing. I just depends on what you're doing. I use the low tack, blue 3M painter masking tape for masking.
The Finesse stuff is cool because it is very thin and doesn't leave much of a tape ridge. But it will only go around the most gentle turns. The 3M blue vinyl stuff will turn a reasonable corner, but it's pretty thick and will leave a ridge.
Logged
Allan Perret
2017
Trade Count:
0
Admiral
Proverbs
Re: Masking Tape
Reply #5 on:
April 04, 2011, 02:26:07 PM »
I just got a roll of the "Delicate Surface " Frog tape. Its yellow vs the regular green Frog tape. Seems to have even less tack than the blue painters tape and it is a lot thinner. I think it might do double duty as both a fine line (but only for straight lines) and a masking tape. Big box stores only have the green version, had to go to Sherwin Williams for the yellow..
Logged
Allan Perret
AMA 302406
Slidell, Louisiana
Chris Edinger
Trade Count:
0
Commander
Hawker Hurricane
Re: Masking Tape
Reply #6 on:
April 04, 2011, 04:15:39 PM »
The 3M blue tape is available at all auto paint supply stores.. here in the midwest you can also get it at most auto parts stores. I sometimes get mine at O'Rileys or NAPA... havent seen the Finesse tape... will try to find some..
Logged
Lee's Summit MO
AMA 896082
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Re: Masking Tape
Reply #7 on:
April 04, 2011, 04:25:13 PM »
Anybody notice the rather extreme price increase in 3M Blue vinyl tape? I just bought a roll from the local auto paint guy and it was about $11.75 for a 36 yard roll of 1/8". I checked online and that seems to be the going rate. Sheesh! Maybe Finesse has something that will go around tight corners.
Logged
Mark Scarborough
2015
Trade Count:
0
Admiral
Re: Masking Tape
Reply #8 on:
April 04, 2011, 04:51:29 PM »
there is another brand, I need to look when I get home,, its orange, and I like it better than 3M,,,
Logged
Dan Bregar
24 supporter
Trade Count:
0
Captain
Field Marshall
Re: Masking Tape
Reply #9 on:
April 04, 2011, 06:24:47 PM »
Guys
I called a couple of auto body supply stores today asking for the Scotch blue fine line tape, and both places told me it has been replaced with stuff that is kinda purple in color. Does this sound correct or is this a totally different type of tape. I'm trying to mask some curves and radii corners. I don't want to get the wrong stuff.
Looking at the Finesse Edge stuff and maybe this is what I want. (Thanks Allan for that link)
Logged
AMA 33676
PJ Rowland
Trade Count:
0
Admiral
Re: Masking Tape
Reply #10 on:
April 04, 2011, 08:06:53 PM »
Wont leave a ridge if you colour sand with 2000 in between coats.
Logged
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Re: Masking Tape
Reply #11 on:
April 04, 2011, 10:39:59 PM »
PJ,
Not if you're using metallic or pearl paint. You can't sand it. At all. Trust me on this. Solid colors can be sanded. Lightly.
Logged
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Re: Masking Tape
Reply #12 on:
April 05, 2011, 09:38:29 AM »
Mark Scarborough had a good suggestion. Instead of 3M vinyl tape, FBS Proline tape is about the same stuff (mark says it sticks better) and is about half the price. I just ordered some.
Logged
Mark Scarborough
2015
Trade Count:
0
Admiral
Re: Masking Tape
Reply #13 on:
April 05, 2011, 11:15:44 AM »
On an additional note about the FBS tape, I like it better than the 3M, it seems more stable when you pull corners to me.
I also like the orange color MUCH better than the blue. it seems to help with layout, ie greater contrast to visualize what you are laying down.
Logged
Dan Bregar
24 supporter
Trade Count:
0
Captain
Field Marshall
Re: Masking Tape
Reply #14 on:
April 05, 2011, 06:18:49 PM »
OK guys. I picked up some 3M vinyl tape 471+ today. It has number 06404 on the package and says "improved Adhesion" It's kind of a blueish purple color. Is this the correct stuff ?
Logged
AMA 33676
Alan Resinger
Trade Count:
0
Captain
Welcome to the Stunt Hanger.
Re: Masking Tape
Reply #15 on:
April 06, 2011, 08:18:57 AM »
That's the stuff you want. It is really better than the old 471. I've been using it for about a year and it adhears better on curves and still doesn't lift the preceeding coats.
Logged
Dan Bregar
24 supporter
Trade Count:
0
Captain
Field Marshall
Re: Masking Tape
Reply #16 on:
April 06, 2011, 06:02:27 PM »
Hey Alan
Thanks a bunch. That's what I was wanting to hear. Thanks for your reassuring response !
Logged
AMA 33676
Neville Legg
Trade Count:
0
Captain
Re: Masking Tape
Reply #17 on:
April 07, 2011, 10:34:36 AM »
Has anyone tried Frogtape? Google it if you haven't heard of it
It's green oddly enough
Cheers
Logged
(not) Descartes
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Re: Masking Tape
Reply #18 on:
April 07, 2011, 02:04:30 PM »
I used Frogtape when I taped off and painted my address on my trash cans. Used the spray gun and a cool metallic black for the numbers. It bled slightly, but I suspect had I shot some clear first, it would have been fine.
Logged
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Re: Masking Tape
Reply #19 on:
April 07, 2011, 05:43:37 PM »
Hi Randy/Mark,
A source for the FBS tape? I have not seen it around here.
Thanks!
Logged
Big Bear
AMA 95351 (got one of my old numbers back!
Neville Legg
Trade Count:
0
Captain
Re: Masking Tape
Reply #20 on:
April 08, 2011, 04:20:27 AM »
Randy, apparently its water that seals the Frogtape! If you had run a damp a damp sponge over the tape first, it seals the edges!
Cheers
Logged
(not) Descartes
Alan Resinger
Trade Count:
0
Captain
Re: Masking Tape
Reply #21 on:
April 08, 2011, 08:17:19 AM »
Randy,
When you pull the tape off does it croak? Using it doesn't give you warts does it? Are the rolls listed by size such as Tadpole (small), Toad (medium) and Bull (large)?
See you Saturday in Portland.
Alan
Logged
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Re: Masking Tape
Reply #22 on:
April 08, 2011, 09:43:18 AM »
On FBS tape. Here's where I found it:
http://www.azautobodysupply.com/fbsfilitahit.html
Alan,
Well, it's green anyway.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Paint and finishing
(Moderator:
RC Storick
Masking Tape
