  • July 13, 2025, 07:51:04 AM
Author Topic: Randolph Acrylic Lacquer  (Read 2705 times)
« on: February 03, 2012, 03:28:43 PM »
Re: Randolph Acrylic Lacquer
« Reply #1 on: February 03, 2012, 03:44:55 PM »
Howard,
not a chemist, but I would say no,, Acrylic Lacquer is the same as old automotive lacquer,,
« Reply #2 on: February 09, 2012, 06:18:13 PM »
At least it should be compatible with Randolph butyrate. ;D
BIG Bear
RNMM/AMM
« Reply #3 on: February 09, 2012, 09:54:48 PM »
Bill,
actually, I would not be so very sure about that,, It would still however be compatible with your checkbook,, ( in other words, your money could buy both,,  LL~) Randolph has a urethane product under their name as well, doubt its compatible with Butyrate,,
Offline billbyles
« Reply #4 on: February 09, 2012, 11:02:21 PM »
Bill,
Randolph's polyurethane is called "Ranthane" & is an excellent urethane product.  Like most all catalyzed polyurethanes (as Mark knows for sure) it will go over most any undercoat including butyrate dope.  It is available in all of the multitude of Randolph colors plus clear.
Bill Byles
AMA 20913
So. Cal.
« Reply #5 on: February 10, 2012, 09:33:34 AM »
I have found most "lacquer type" products, especially from the same manufacturer, to be compatible in the sense that they will go over each other.  No local source of hobby products has led to years of mixing and matching.  And years of no problems showing up.
BIG Bear
RNMM/AMM
« Reply #6 on: March 04, 2012, 06:48:01 PM »
Bill,
Hi Mark,
I think some of all this is because we are painting small objects when compared to a car or truck..............
Automotive Acrylic Lacquer was a real big item to use for painting our models back in the day.  With a clear butyrate dope top coat.  The acrylic lacquer from Duplicolor works fine for colors on a stunter then hit it with SIG Lite Coat clear, or automotive Urethane for the clear finish coats.  There is no question that it works and has been for over 50 years.
BIG Bear
RNMM/AMM
« Reply #7 on: March 31, 2012, 06:33:20 PM »
I agree with Bill about Dupli-Color and use there clear in the place of regular dope as it is lighter non shrink and  harder,but never as a top cote. The clear sands easily
