  • July 17, 2025, 03:58:34 PM
Author Topic: question for the painters  (Read 1954 times)
Offline RC Storick
« on: March 09, 2014, 11:10:33 PM »
how much clear dope does it take to make a ounce on a plane. A pint, a quart, a half gallon. This is before thinner?
Re: question for the painters
« Reply #1 on: March 09, 2014, 11:28:47 PM »
 Do you mean how much clear does it take, after it dries and gasses off, to add an ounce? I don't know the answer, but even though the thinner evaps out I imagine the clear/thinner ratio comes into play somewhere...
Offline RC Storick
« Reply #2 on: March 10, 2014, 12:39:17 AM »
Easy if I painted a whole quart (before thinner) on how much does it weigh,
Offline Curare
« Reply #3 on: March 10, 2014, 01:12:51 AM »
Not that I'm a painter by trade,(I have dealt with similar coating fun-stuff in the past), but that's a bit of a hard question to answer.
You could lay a super thick coat of dope and get a lot of weight and very little coverage, or thin one and go a mile.
Also are you asking about just the paint, or in a finishing situation, where it's sanded?
For reference, the density of nitrocellulose is 1.58–1.65 g/cm3 (98.63-103lb/ft3). If you figured out your coverage area, and a thickness of dope (this would be a real crapshoot) you could figure out your weight gain. But inconistent application, and sanding between coats will make everything you've calculated wrong.
Greg Kowalski
AUS 36694
Offline RC Storick
« Reply #4 on: March 10, 2014, 01:15:45 AM »
This does not have to be a hard question. 1 pint of UN thinned dope mixed 50-50 for spray weighs how much dry? Not a math quiz please. I have heard people say they spray a quart or two and it only weighs a ounce (which I am not buying).
Offline Curare
« Reply #5 on: March 10, 2014, 02:10:13 AM »
I don't either. Not unless they're sanding the living s**t out of it between coats, so most of that quart ends up on the floor.
A quart is a 946cc, but it still has a solvent in it which will gas off, and having a look at some MSDS sheets most nitrocelluloses are running at around 11-12% volume. (until I can find better info this is all a bit of a WAG).
so by that math, a quart when dry should weigh about 156g, or around 5.5 ounces when absolutely dry.
Greg Kowalski
AUS 36694
« Reply #6 on: March 10, 2014, 08:01:33 AM »
 I'm gonna say it's less than a pint of 50/50 clear to add an ounce of weight. The best way to find out is to weigh the model before and after putting on a measured amount.
Online Larry Wong
« Reply #7 on: March 10, 2014, 08:39:30 AM »
But when spraying you have over spray that does not end up on the plane, but on the floor or just in the air. HB~>
Larry
« Reply #8 on: March 10, 2014, 10:05:00 AM »
dope is a very low solids material,,
i cannot answer specifically, but a ball park,, most dope is reported as being 13 or 14% solids,, which means in theory after all solvents evacuate, you would have 13 or 14% of the weight remaining,, of course taking into account the amount that blows randomly around your shop,,
« Reply #9 on: March 10, 2014, 10:43:46 AM »
On a 700 sq inch plane, it takes about a quart of dope (mixed 60/40 thinner to clear) to gain an ounce. This is from experience shooting clear. I generally weight after each coat of clear (if using dope) and experience says it takes the entire quart, mixed with thinner, to gain an ounce.
Offline 55chevr
« Reply #10 on: March 10, 2014, 10:56:10 AM »
Between the imbedded vehicle in the product and the added thinner the amount that "gases off" appears to be substantial.   The 14% solid mentioned by Mark seems to bear this out.
Joe Daly
« Reply #11 on: March 10, 2014, 11:02:12 AM »
So, just to make sure I'm getting this:  You put a bit over a pint of clear into a 1 quart paint pot, then you put a bit less than a pint of thinner and stir.  Then you shoot the whole quart onto a plane (and half your shop), and when you're done and the plane has dried for a bit, it's one ounce heavier?
« Reply #12 on: March 10, 2014, 12:02:24 PM »
I think there are numerous variables here including brand of dope (Certified has lots more solids in it for example) but my own experience is that on a 700 sq. airplane an airbrushed coat cut 70% will be around 1/2 ounce.  If thinned only to flow well and brushed then 1 1/2 ounces per coat.  I would then suppose that a coat sprayed with a regular gun would be in the one ounce range.
« Reply #13 on: March 10, 2014, 03:02:56 PM »
Dave makes a good point. Looking at clears that are in the 13-14% range for solids, this is the case. I've used some clears with a higher (and lower) solids ratio and so, it takes a bit more or less to get to an ounce.
And Yes Tim, I mix up about a half gallon of clear (with 60% being thinner and 40% being butyrate lacquer) and shoot it all. Normally it takes 3 or 4 coats to go through the whole half gallon. Windy used to shoot a gallon this way.
« Reply #14 on: March 10, 2014, 06:43:38 PM »
 Very interesting, thanks for the info Randy. y1
