  • July 15, 2025, 05:24:04 AM
Author Topic: Profile Fuselage Dope Finish  (Read 1418 times)
Offline Robert Organ
« on: February 04, 2010, 11:56:25 AM »
I know there have been a lot of threads on this subject, but in the fifties and sixties I remember using balsa fillercoat followed by 2-3 coats of   butyrate color and then 2 coats of thinned butyrate clear (sanding between all but the final color and the final clear coat) for a very good finish on the fuselage and tail feathers of the many Ringmasters that I built and flew in this era. Do I remember this right and what can I use for fillercoat that is compatable with Brodak butyrate dope, I am wondering about minwax waterbase ? I am open to any suggestions on this subject, including any better alternatives to this procedure. I just remember that it worked very well at the time and was pretty easy.  Thanks, Bob
« Last Edit: February 04, 2010, 12:49:21 PM by Robert Organ »
Bob Organ   AMA 316747
Re: Profile Fuselage Dope Finish
« Reply #1 on: February 04, 2010, 12:00:22 PM »
take a look at Warren Leadbeaters post just down a bit - he has a simple finishing technique that would be ideal for profiles
« Reply #2 on: February 05, 2010, 08:51:03 AM »
Thanks Wynn for your reply, I really thought that I would get more response to this as so many build profiles. I have been in RC off and on since the sixties and the only building I have done in a long time is of the ARF variety. I think my main issue is I really want a different solution than covering the airplane with paper but if thats best than I can do it that way. I think my main question is the compatibility of dope and poly fillers. Thanks again, Bob
« Reply #3 on: February 05, 2010, 11:07:09 AM »
In my experience the poly fillers work great under dope.  Do not use them over dope unless the dope has gassed out for a couple of weeks.
Offline Balsa Butcher
  • High Desert Flier
« Reply #4 on: March 02, 2010, 04:50:12 PM »
If you are going to use dope anyway, why not just use it and avoid any comptibility issues. A few coats of clear, apply Med silkspan - I think it adds to the stiffness of a profile fuselage, (and tailfeathers) others experience may differ- some filler coat, paint, clear, fly. Not as labor intensive on a profile as one may think, especially if the wings are done in monokote.  8)
Pete Cunha
Sacramento CA.
AMA 57499
