  • July 20, 2025, 10:38:18 AM
Author Topic: Primer as block coat over Dupli color?  (Read 1327 times)
« on: November 04, 2020, 10:52:32 AM »
Has anyone sprayed primer of Dupli color to act as a block coat then applied the Dupli color over it? Had an area that was light color under covering and when I shot the color for the checkerboard got some light spots over the leading and trailing edge areas. Thought I could shoot a light block coat then top coat over a constant base. Any thoughts?
Best,    DennisT
Re: Primer as block coat over Dupli color?
« Reply #1 on: November 04, 2020, 12:08:41 PM »
As I usually say, you pays your money and takes your chances. Anytime you mix materials, you take a chance of incompatibility. It's always safer to use materials that are they same - lacquer with lacquer, enamel with enamel, etc. Even that can be dicey if from different manufacturers.
So, I'd do a test first.
« Reply #2 on: November 04, 2020, 12:39:31 PM »
Well as the paint dried it seems to be covering better so might just do a another coat over the LE & TE and call it good. Should have put the primer on first to get a even base, tried to save some weight, kinda worked.
Best,    DennisT
« Reply #3 on: November 04, 2020, 01:45:51 PM »
The last 3 or 4 planes I've build had no filler coat or primer. I slightly tinted some clear and just used that to build up the surface for paint. Much lighter.
