Building Tips and technical articles. => Paint and finishing => Topic started by: James Holford on August 11, 2017, 07:38:45 PM
Building pat kings Ringmaster Trainer III. Its profile with plank wing..so lots of balsa.
Which clear dope should I use to prep the wood to prime?
I think I read somewhere like 2 light coats of thinned dope then go ahead with the DC540.
Would it be Butyrate or Nitrate?
Not set up to spray so will have to brush it on.
I would put 3 coats of dope (either, I always use Butyrate) thinned 50%, lightly sand each coat with 360 or 400, cover it with light or medium silk-span, 3 coats of dope, lightly sand each coat, then spray primer. I know its a trainer, but practice your finishing techniques on it. As small as it is there is not much area to sand. Have fun!
Don
Thanks for the reply Mr. Don!
Its full size Ringmaster lol.
Imagine a beginner Ringmaster with 42" ws lol
It is small compared to a full fuselage, 60 inch span, 680 square inch stunt plane, now that takes a whole lot of sanding!!!
Don
Oh yea compared to that I agree lol(https://uploads.tapatalk-cdn.com/20170812/6da72d7d1792a9185f21810414d6d572.jpg)
James,
Really nice wood work on your Ringmaster. H^^
How did you glue the bottom sheeting on after you did the top?
Charles
No sheeting.. 3/8 thick sheet lol
