  • July 15, 2025, 10:58:46 AM
Author Topic: Polyspan then superfil vs. superfil then polyspan  (Read 1423 times)
Offline Duke.Johnson
« on: May 08, 2013, 10:08:09 PM »
I know it might be somewhere in the history of the forum threads. But, hopefully this is a simple one.  I bought my first tubs of superfil and didn't know if I put on all the polyspan then laid the fillets with superfil or vise versa?  Can you dope superfil or do you cover it first?  Sorry if this is stupid, but there's a first time for most everything. Thanks for the help.
Re: Polyspan then superfil vs. superfil then polyspan
« Reply #1 on: May 08, 2013, 10:27:05 PM »
Duke,
for what its worth,,
what I typically have done is cover the wing before it goes in the fuse. Most of the work is  done on the fuse as well, covered and doped
Then put the wing in the fuse align and secure.
then Is when I do my fillets, it gives me more strength on the wing being covered first, It also gives you a more stable substrate to create your fillets on.
I then never cover the superfill. Ideally when you are done with it, it wont need anything except a coat of primer...
there are several threads which covered different application ideas, mostly they are subtle differences,, Probably worth spending some time with the search, I think you would find good info as well as any other answers here
Offline Balsa Butcher
  • High Desert Flier
« Reply #2 on: May 08, 2013, 10:59:59 PM »
Agree with above. The only thing I would add is I use rubbing alcohol to moisten shaping tools or a finger when applying and shaping uncured superfil. It seems to work better than water. The handle end of an small xacto knife is a good tool to form a radius. I think everyone who uses the stuff has their own preferred tool. Another tip is make sure the hardener (white stuff) is stirred. The liquid hardener can separate from the medium which can cause curing problems. Ask me how I learned that.  HB~> 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #3 on: May 09, 2013, 12:04:20 PM »
Thanks guys.  Do you leave the covering on the wing/fuse joint also? Or raw balsa?
  • High Desert Flier
« Reply #4 on: May 09, 2013, 12:33:55 PM »
I apply a few coats of dope to the covering to get it tightly bonded to the balsa then apply the Superfil over it. Before it cures shape it to a radius, sand as necessary after it hardens, then prime/paint etc. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Online RC Storick
« Reply #5 on: May 09, 2013, 01:14:59 PM »
James this is the correct method.
« Reply #6 on: May 09, 2013, 01:55:56 PM »
Yep, covering, a few coats of clear THEN fillets. Makes it easier to sand them, too since it's harder to go through the clear and paper.
« Reply #7 on: May 10, 2013, 08:32:50 AM »
Thanks again!
