  • July 30, 2025, 07:53:12 AM
Author Topic: Polyspan around curved wingtips demonstration.  (Read 21175 times)
Offline Brent Williams
« on: March 07, 2024, 12:11:27 PM »
Have you ever wondered how to get polyspan to form around curved wingtips with no cuts? I filmed a demonstration given by Roger Kramar as he covered a wing panel with a curved wingtip using a single sheet of Polyspan with no cuts.  He shows the process of using a monokote iron to tack and shrink the Polyspan around complex curves.   He and Gordan Delaney have used this method for many years on their beautiful front row quality ships.
Re: Polyspan around curved wingtips demonstration.
« Reply #1 on: March 07, 2024, 03:51:01 PM »
That was informative!  I have used a similar method to help seal the polyspan.  Don't shrink it on the open bays before you dope.  Then, with the dope wet use the iron or heat on low heat to shrink the polyspan.  It really seals it up and you don't get those awful holes.  I do monokote like Roger but I had never thought of using the same technique with polyspan - Thanks.  So does the next plane with polyspan comes with three people to hold it for me?  ???
Offline Larry Renger
« Reply #2 on: March 07, 2024, 06:15:18 PM »
A really useful show of how to do a wingtip ended panel. I learned a lot! Forms a perfect base for my following rant. R%%%%
Unless you are going for a Nationals 20 point finish, look into covering the polyspan with park flyer film.  Instant colored composite finish that has proven remarkably durable.
If you are going for the top quality finish, scuff the outer surface of SLC film, cover and you are ready for your top coats of paint. No primer and prep required. Lighter, tougher, cheaper, quicker, durable, less dope fumes, what is not to like?
See the SLC over Polyspan thread. Can 112,000 views be wrong? Try it and let us know. A lot of viewers are looking to see how it works. So far the reports have been positive.
I have used this scheme for years and would never switch back to tedious, multiple layers of dope to fill a porous covering material and then try to make it shine. Life is too short for that.
By the way, Hi Gordy! Haven’t seen you in a long time. 🤠
Best regards, Larry
« Reply #3 on: March 07, 2024, 07:49:33 PM »
 Great video! I use Polyspan exclusively but have only ever used my heat gun with it. For some reason I've never even thought of using my iron, DUH, looks like a better way, a lot less chance of the dreaded burn through.  y1
Offline bill bischoff
« Reply #4 on: March 07, 2024, 08:30:35 PM »
One of the nice things about adhering Polyspan with ModPodge is the ability to shrink, stretch and stick the covering all in one step, like any other iron-on covering. Somehow, ironing wet dope "goes against the grain" for me, but I can't argue with results.
Offline Miotch
« Reply #5 on: March 08, 2024, 07:33:12 AM »
Great video !!  I actually ended up using this technique on my last build when putting on heavy silkspan and I got the best wingtips I ever did.  Had to mist the silkspan a few times while doing it and it you certainly can't pull and stretch like the polyspan, but using the iron on the tip while applying did allow me to get it down nicely without any wrinkles.  The next one I build, I'm going to try some stuff from Joann's fabrics that is supposed (we'll see) to be similar to polyspan and I'll certainly try the iron and pull technique like this video.
Offline Walter Hicks
« Reply #6 on: March 08, 2024, 06:07:02 PM »
Thank you Brent for sharing this with us, great useful information.
Offline bob whitney
« Reply #7 on: March 08, 2024, 09:29:03 PM »
Sparky has a video showing how he dose his wing tips .
rad racer
Offline Mike Quinn
« Reply #8 on: August 20, 2024, 05:00:04 AM »
Hi
What density Polyspan ( g/m2 or oz/sq yard say)?
Cheers
Offline Steve Dwyer
« Reply #9 on: August 23, 2024, 10:41:27 AM »
This was a good video of another individual applying Polyspan. Next time I will try using the heat iron for the tips instead of the heat gun. The heat gun tends to overheat the fabric too quickly depending on your finesse often setting it before the wrinkles are completely shrunk. Careful use of the gun, however, can give good results but I find often I have had a few very slight wrinkle lines that will not completely reduce away leaving the tips 98% to 99% from perfect.
Finding the shiny side always seems to be a challenge and I have on occasion installed it incorrectly leaving the standing hairs.  Fortunately, they can be lightly sanded off using 600 after a coat of clear or two. Somewhere someone suggested dragging the fabric over the wing structure will show the shiny side easily sliding while the dull side will snag. I haven't tried this yet. I have wondered how the fabric is made, does the shiny side have a glazing applied?
I have read some fabrics are smoother on one side depending on the type of weave. So, I ask if there is no glazing used then why do the same threads of the woven fabric come out one side rough (dull) while the other is smooth? Perhaps the movement of the fabric over the loom roughens the fabric causing a dull side?  Puzzling.
