  • July 20, 2025, 12:09:00 AM
Author Topic: Pneumatic buffer / polisher  (Read 1204 times)
Offline Allan Perret
  • Proverbs
« on: May 13, 2011, 02:36:38 PM »
Been looking for something for some time now.  Saw this item at Harbor Freight.
http://www.harborfreight.com/3-inch-pneumatic-polisher-kit-99934.html
For $30 (what I paid in the local store) thought I'd give it a try, fully expecting it to be too fast / aggressive for model work.
I was sure I would try it out and end up returning it.
But, its a keeper.     #^
Small and compact enough for easy control, weighs about 1.75 lb.  It has a built in speed valve, and by using that and regulating air supply down to 40psi, you can get the rpm down around 100~200, and it maintains the torque so it doesnt stall out.  Has 2 different foam pads and a wool pad, all velcro attachment.  Those are also available as a seperate kit. ($12 in my store).  I use rubbing compound with the coarse pad, polishing compound with the fine pad, and swirl remover with the wool pad.  Works great.
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Pneumatic buffer / polisher
« Reply #1 on: May 13, 2011, 04:36:53 PM »
Cool, Allan. Nice tip.
« Reply #2 on: May 13, 2011, 05:26:38 PM »
I will soon have one of these, Allan!  Thanks for the tip.  (Should also work well on instruments! ;D)
Will
Offline ray copeland
« Reply #3 on: May 13, 2011, 07:49:53 PM »
Great tip Allan !  I love it, need a new gadget.    #^
