  • July 16, 2025, 11:23:45 AM
Author Topic: Panel Lines over Dope  (Read 2266 times)
Offline t michael jennings
  • AMA 83322
« on: April 26, 2016, 06:18:56 PM »
Gentlemen,
Sprayed a coat of Brown SIG dope on my current building of a P-39 Bell Airacobra.
How many days should be delayed before putting on the Panel Lines due to the dope Outgassing?
Thanks for your answers.
T Michael Jennings     ???
Knoxville, TN.
Re: Panel Lines over Dope
« Reply #1 on: April 26, 2016, 07:00:52 PM »
Gentlemen,
Knoxville, TN.
T.M.J.
Are you going to put more dope over the panel lines? Fuel proof lines?
Charles
« Last Edit: April 26, 2016, 08:18:52 PM by Avaiojet »
« Reply #2 on: April 26, 2016, 07:15:03 PM »
You can put down the ink panel lines two hours after the dope is applied.  The gassing is no consequence to anything.  Then you should spray one or two dust coats of clear over the ink to lock it down.  You might let that dry overnight before moving on.  Cure time becomes important after all final coats are on- before flying 3-4 days,  before wet sanding and rub out 3-4 weeks to reach real hardness.
  • AMA 83322
« Reply #3 on: April 26, 2016, 07:36:14 PM »
Charles,
Dave,
Thanks for the feedback.
After the Panel Lines are on, will apply a light coat of Clear Klass Kote.
Thanks again.
T Michael Jennings
Knoxville, TN.
« Reply #4 on: April 26, 2016, 07:55:11 PM »
   Dave Gierke ( might not be spelled correctly) published an article in Flying Models years ago (I think it was) on doing ink lines. Keep some baby powder or corn starch handy to rub down the surface if the ink doesn't want to transfer well and skips. Just a light dusting and rub in gently.Keep some rubbing alcohol handy to wipe off mistakes with clean cotton rags or Q-Tips.  When finished, apply the clear as already described. This also works with any kind of paint.
Offline billbyles
« Reply #5 on: April 26, 2016, 07:57:34 PM »
I recommend using the Klass Kote polyurethane clear rather than their epoxy clear to avoid the yellowing of the epoxy clear.  Klass Kote is a very high quality product but all epoxy clears will turn yellow.  This has been Brett Buck's recommendation also as he has considerable experience with Klass Kote products.
Bill Byles
AMA 20913
So. Cal.
