  • July 17, 2025, 08:30:20 PM
Author Topic: Pactra Formula U - yes/no? - thinner?  (Read 2882 times)
Offline Terry Caron
« on: March 01, 2014, 03:58:02 PM »
I've acquired several dozen 8 oz cans (not spray) of the original Pactra Formula U polyurethane in a buncha colors, still liquid.
I'm not at all familiar with it.
Good stuff? Bad stuff?
If good, is there a suitable thinner currently available for it?
I think it was OOP for a while, but there's an online HS selling 3 1/2 oz cans of Pactra Formula U - over $31/can!
Another lists spray cans so I guess its back.
Don't know if it's the same stuff or not.
Thanks.
Terry
Update: ckd again - it's $31/ctn of 6  ::)
« Last Edit: March 01, 2014, 09:54:35 PM by Terry Caron »
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Re: Pactra Formula U - yes/no? - thinner?
« Reply #1 on: March 01, 2014, 04:13:46 PM »
I also have a lot of old paint around.  Acetone always works for me.  Most high-priced thinner are just acetone.  In a trial-and-error test acetone is always a good first shot.
Offline Terry Caron
« Reply #2 on: March 01, 2014, 04:16:57 PM »
I have acetone so I can try it if F U (pardon the expression) can be recommended.
Also found some old posts elsewhere saying "paint thinner", so'll probably work.
Terry
p.s. - discovered "thinner" is for lacquer; reducer for others, like polyurethanes.
Live and learn.
p.p.s. - Opened a can to try it; waiting for it to dry.
BUT - tried to clean the brush in acetone - a total bust - didn't even discolor the acetone.
Lived longer, learned a little more.  S?P
« Last Edit: March 01, 2014, 08:46:06 PM by Terry Caron »
AMA 249824
NRA Life Member
Offline Terry Caron
« Reply #3 on: March 06, 2014, 02:08:44 PM »
Sig's current thinner cleaned Formula U from a brush just fine, so looks like it'll work.
Terry
AMA 249824
NRA Life Member
Offline RC Storick
« Reply #4 on: March 06, 2014, 05:22:36 PM »
Not sure but I think its a enamel so it would need reducer not thinner
Offline Terry Caron
« Reply #5 on: March 06, 2014, 05:38:47 PM »
Any idea what'll happen If I use Sig thinner instead of the apparently unobtainable reducer?
Sure cleaned the brush well.
Terry
AMA 249824
NRA Life Member
« Reply #6 on: March 06, 2014, 05:54:21 PM »
  Its a one-part enamel and as I recall, turpentine or "paint thinner" works, nothing exotic is required, for sure.
   I used a fair bit of this back in the day. The only issue I ever had was that the gloss was inconsistent from color to color, and the clear was amber. It also had a tendency to remain rubbery, depending on the color.
Offline Terry Caron
« Reply #7 on: March 06, 2014, 06:01:28 PM »
Thanks guys -
I'll just test some and see.
If it won't dry or whatever, paint thinner's easy to get so I'll try that.
Terry
AMA 249824
NRA Life Member
Offline Peter Ferguson
« Reply #8 on: March 07, 2014, 01:13:58 PM »
I used it years ago and my experience with it was similar to Brett's, inconsistent drying led to soft areas. You may want to make up some test pieces before putting it on your plane to avoid starting another thread titled "removing Formula U from my plane".
Peter Ferguson
Auburn, WA
Offline Terry Caron
« Reply #9 on: March 07, 2014, 01:22:23 PM »
 LL~
Trying it on test pieces now Peter.  S?P
Terry
AMA 249824
NRA Life Member
Offline Ciaran McCarthy
« Reply #10 on: March 17, 2014, 05:03:48 PM »
I have recently returned to C/L and building. I still have lots of Pactra Formula U left from when I bought up big in a closing down sale (due to the owner's terminal illness). Along with many other products for basis of comparison, I have used Pactra Formula U a lot. I like it. It is a superb paint, but like all paint products, you need to be aware of its characteristics.
I originally had the proper Pactra Forumula U thinner along with the Pactra Prep undercoat product and its thinner -which is a  lacquer & lacquer thinners.
Thinners
Pactra Formula U is a polyurethane enamel. IME enamel thinner proved the best substitute for the original Pactra Formula U thinners. I was spraying using an Iwata cabinet maker's gun. It works as well as the original thinners for spraying. But buy enamel thinner intended for spraying, not cheaper GP (general purpose) thinner (which is also an enamel thinner) but low quality. It'll work, but not as well and the price difference is worth it for the finish and spray characteristics the higher quality thinners will offer. Cheaper GP thinners is fine for cleanup.
Spraying with Pactra Formula U
Three things to keep salient in mind.
1. Light coats. If you're not achieving the opacity you want in a single coat or second coat, don't persevere with further application or you will get a wet coat, sags and run/s. Let the first and immediate subsequent second coat dry, then come back and recoat in the time period according to the instructions on the can. In the particular with Forumula U, do try to avoid a wet coat and runs. Why? Pactra Formula U is great paint. It's completely fuelproof and presents a deep lustre protective finish will will keep for 20 years. But, it dries as hard as a rock. Sanding it back really is a PITA. So . . . for the opacity you want, the rule is . . . light coats.
2. Practice on scrap first until you have the pressure and thinning ratio right for your weather conditions. Don't spray when its very hot or hot 'n humid if you can avoid it, as this will significantly affect the flash time of the paint and thus working time of the paint, particularly important if you want to apply a second coat and it's a larger model.
3. I've never found it to be any good for brush application. No matter the thinning ratio, it just sets up too fast and you'll get that dry coat look with a brush. Spray application only.
Hope those tips help.
Offline Terry Caron
« Reply #11 on: March 17, 2014, 05:08:19 PM »
Thanks Ciaran - excellent report and info.
I've saved a copy for when I give it a try.
regards,
Terry
AMA 249824
NRA Life Member
« Reply #12 on: March 19, 2014, 09:15:58 AM »
IMHO.
If I couldn't get Formula U thinner, I wouldn't use the product.
But that"s me.
Edited for spelling.
« Last Edit: March 19, 2014, 11:04:16 AM by Avaiojet »
Offline Terry Caron
« Reply #13 on: March 19, 2014, 11:02:15 AM »
Application, drying, final finish and fuel-proofness are easily tested.
I have about 75 cans in a dozen colors so it won't hurt to try it on test pieces - if it works, good deal; if not, no harm done. ;)
Terry
AMA 249824
NRA Life Member
