  • July 17, 2025, 08:32:31 PM
Author Topic: thinner to dope ratio  (Read 2166 times)
Offline adam collver
« on: March 18, 2014, 09:45:33 AM »
I was wondering after you cover with silk span and put on colour for your top clear coat what would be the thinner to dope ratio.
Adam
Re: thinner to dope ratio
« Reply #1 on: March 18, 2014, 09:58:15 AM »
That depends.  You want it thicker for brushing, thinner for spraying.  For all I know, if you've got an HVLP system you'll want a different viscosity than for old-style.
Now, if that doesn't make things vague enough, different brands of dope are thinner or thicker in the can -- Sig and (I think) Brodak are thinner, Randolph's is thicker.
Ideally you thin enough to get the right consistency, not to get some specific paint/thinner ratio.
« Reply #2 on: March 18, 2014, 10:21:01 AM »
Thanks Tim Im using Randolph's and I'm brushing it on, before I colour and then span is on how many coats of clear do u put on before colour?
Offline RC Storick
« Reply #3 on: March 18, 2014, 10:34:58 AM »
About 3 coats will start to give a sheen sometimes four. Then apply color and apply clear after that. This all varies on your technique in application.
« Reply #4 on: March 18, 2014, 04:42:57 PM »
Adam,
You might want to look at the Preval spray system. This is a simple cheap self contained spray system available from Home Depot. Here is the Preval web site http://store.preval.com/?gclid=CP_R-5SGnb0CFQ8OOgodvnoA1w. Each unit can cover 2 - 35 size ships. If you spray mix the clear 50/50, watch the temp and humidity (less than 80F and 68% Hum). If the humidity is higher you will need to add 1 -2 % retarder. Wait at least 1 hr between coats, 2 should do it for a top coat. After complete let it gas off at least a week before you fly.
If you brush, I think 40/60 thinner/dope. Use a very soft brush apply in one stroke to avoid softening and smearing the color.
Best,        DennisT
