  • August 05, 2025, 02:32:22 AM
Author Topic: Want to spray  (Read 1055 times)
Offline adam collver
Want to spray
« on: August 25, 2013, 10:57:24 AM »
How much psi does a compresser have to have to spray dope?
Offline Allan Perret
  • Proverbs
Re: Want to spray
« Reply #1 on: August 25, 2013, 11:26:39 AM »
Pressure is not normally the issue as most compressors go up to about 100 psi and most guns need only 35~50 psi at the inlet.   Its more about the volume needed from the compressor/tank system to keep up with what your gun requires.  For a full size gun I would suggest at least a 20 gallon tank.  Detail guns would work OK with the smaller pancake type units used for pneumatic nail guns.
What gun do you have or looking at getting ?  Check the manufactures specs on the gun for the CFM required and try to match that to the compressor's output.  You can get by with a lower compressor CFM rating than the gun CFM with a larger tank volume.
Allan Perret
AMA 302406
Slidell, Louisiana
