  • August 04, 2025, 12:37:03 AM
Author Topic: Lacework  (Read 46111 times)
Offline Sean McEntee
Lacework
« on: April 26, 2015, 11:23:06 AM »
Many many years ago, painting with lace was the thing.  I've seen several models in magazines from back then I think it looks pretty awesome. To the guys who were around back then and used this technique, describe the process?  Thanks a bunch!
Offline tom brightbill
Re: Lacework
« Reply #1 on: April 26, 2015, 12:07:15 PM »
Paging Mark Scarborough!  (His lace work earned 20 points at VSC a couple years ago.)
AMA 34849
Re: Lacework
« Reply #2 on: April 26, 2015, 12:54:00 PM »
Yea, Mark used candy colors and fish net stockings to get the effect. Very cool.
Offline Bootlegger
Re: Lacework
« Reply #3 on: April 26, 2015, 03:19:15 PM »
 Sean, I sis a couple of my models with lace that I picked up in a fabric store, actually had my wife pick it up for me for the obvious reasons!!
 Any way I had the color that I wanted already sprayed, and pinned the lace down so it would not blow around, and shot the other color at low pressure using my air brush, they came out very well I think.
 You might get some poster board and shoot your color thru the lace onto it for practice.
  Let us know what you think..
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Lacework
« Reply #4 on: April 26, 2015, 04:01:22 PM »
Oh no, another modeler succumbs to the temptation of wrapping his plane in ladies' underwear!
Sean: +1 on paging Mark.
The basic idea that I dimly remember from growing up in a paint shop, and from Mark's comments, is that you get the base perfect, then you tape the lady's underwear onto the plane, then you fog on the contrasting color.  Then you throw the underwear away because she will notice that something has been done with it.  Then you put clear over everything, and hope to heaven that your airplane never gets damaged, because you'll never, ever be able to repair the paint job.
If that explanation isn't garbled enough to get Mark on to correct and expand, then he's just not reading the forums.
Re: Lacework
« Reply #5 on: April 26, 2015, 05:36:43 PM »
I have the the construction article from NOV 1959 FM and hand-drawn plans ala Dad for Arthur Alfieri's "Ruby", and will commence building once the T-6 gets done. I think some lace would look cool on it.
I saw a video on facebook of a guy doing essentially the same thing with some old jeans and a motorcycle fender.  He laid down the white, and let it get good and hard for month or so.  Then he painted on the blue and while it was wet, laid the jeans down over the paint.  Patted it down real good and lifted.   The result looked incredible.  That got me thinking about the lace, and would be cool to try.
Thanks all for the comments!
« Last Edit: April 26, 2015, 09:15:49 PM by Sean McEntee »
Offline Larry Wong
Re: Lacework
« Reply #6 on: April 26, 2015, 05:48:21 PM »
Sean check out Paul Pamposa's Temtation great lacework.  y1
Larry
Re: Lacework
« Reply #7 on: April 26, 2015, 05:58:58 PM »
Hey Sean:
It sounds like the guy was doing the opposite of what I know of as lacework: instead of using something as a mask he used something to seletively lift paint off of the work.  It's an interesting technique, though.  I can just imagine getting it wrong and ripping up your nice white undercoat...
Woodgrain next?
Offline Bootlegger
Re: Lacework
« Reply #8 on: April 26, 2015, 08:01:46 PM »
  No, Tim W, I used the lace patterns that you can buy at the fabric stores.
 There are a lot of different types of patterns there for your choosing, just go check it out. y1
Gil Causey
AMA# 6964
Offline Larry Borden
Re: Lacework
« Reply #9 on: April 26, 2015, 08:05:15 PM »
I did the lace thing on one of my Ringmasters. I masked around the basic design and laid the lace down and sprayed a light coat of contrasting color and lifted the lace off while paint was still wet.  Came out pretty neat, if I do say so myself. :) Got the lace from Jo-Anns fabrics.
Re: Lacework
« Reply #10 on: April 26, 2015, 09:15:28 PM »
Hey Sean:
Woodgrain next?
Yeah it was kinda backwards from what you guys are describing.  Did look cool though.
Stained balsa would look cool too!  That would take some thinking and experimentation though.
Offline Target
  • C/L Addict
Re: Lacework
« Reply #11 on: April 26, 2015, 09:58:08 PM »
How about a picture of an example of said lacework painting for a Newbie?
Chris
AMA 5956
Re: Lacework
« Reply #12 on: April 26, 2015, 11:54:13 PM »
uh,, was somebody trying to get ahold of me?
sorry I was in my zen mode being intimate with my roll of 2 3/4" 320 grit and a willing airframe,,
now its bed time,, I will try to type up a description of my Avenger tomorrow,,
its quite simple,, ( most of the really cool effects are totally simple),,
Re: Lacework
« Reply #13 on: April 27, 2015, 07:30:39 AM »
Friend of mine had a car with "marble" racing stripes.  The guy who painted it went a little nuts with candy colors, and that prismatic paint that changes blue/green/purple depending on angle.  He used something along the lines of a trash bag applied while the paint was wet to lift some of the paint in a "marble" pattern.  It didn't look nearly as terrible as some of his tangerine with color shifting paint monstrosities, but we never got tired of poking fun at my buddies Hefty bag racing stripes.
Re: Lacework
« Reply #14 on: April 27, 2015, 11:56:40 PM »
Basically, the Avenger was sprayed a gold pearl base,, let dry thouroughly,, then I stretched a fishnet stocking over the wings, taking a fair amount of time to make sure the stretch evenly distributed the pattern,, I sprayed red/burgandy pearl through the fishnet,, starting at the leading edge, and blending it back to nothing,, after again it dryed,, I carefully lifted of the stocking and sprayed a coat of gold candy over it to lock the pearl and add depth,, then graphics over that,, then clear,, I really cant post a good picture,, the effect is subtle enough as to make photographing it challanging, I do think I have one shot that shows it,, let me look
Offline Target
  • C/L Addict
Re: Lacework
« Reply #15 on: April 28, 2015, 08:01:11 AM »
I get the idea, that IS pretty cool.
Thanks for the picture, Mark.
R,
Chris
Chris
AMA 5956
Offline JIM Nordin
Re: Lacework
« Reply #16 on: April 28, 2015, 10:02:18 AM »
Not a airplane but same idea
Re: Lacework
« Reply #17 on: April 28, 2015, 02:41:54 PM »
Here is a Ringmaster that I tried my hand at painting using lace. Left wing, not so good, right, acceptable.
Re: Lacework
« Reply #18 on: April 28, 2015, 07:06:15 PM »
except I think that is colored carbon fiber cloth molded
Re: Lacework
« Reply #19 on: April 28, 2015, 08:06:32 PM »
Or it's this stuff.  How can I waterproof a Legacy?
« Last Edit: April 28, 2015, 09:15:50 PM by Tim Wescott »
Offline JIM Nordin
Re: Lacework
« Reply #20 on: April 28, 2015, 08:19:49 PM »
This is sprayed through a drawer liner no water involved
Re: Lacework
« Reply #21 on: April 28, 2015, 09:11:57 PM »
Wow Mark, thats amazing!  Looks incredible. Yeah I will have to give this a try...
Re: Lacework
« Reply #22 on: April 29, 2015, 07:59:37 PM »
Jim, I stand corrected,, I did not look close enough
