  • June 17, 2025, 06:54:51 AM
Author Topic: Dope pulling away from plane  (Read 1684 times)
Offline mccoy40
« on: March 21, 2019, 08:27:01 AM »
All,
I've been doping a profile fuselage for the past month or so. About six coats of nitrate, two of butyrate and filler. I let it sit for a couple of weeks to settle and painted it with some red colored SIG butyrate Dope.
When I cam back later that day the Red had pulled away from the wood in the corners between the rudder and fuselage and the doubles and the fuselage.
How can I correct this? More dope ? thinner?
 mw~
Joseph Meyer
Philadelphia, PA
Offline mccoy40
Re: Dope pulling away from plane
« Reply #1 on: March 21, 2019, 02:25:37 PM »
Cyano on the rudder - slow set and carpenters glue on the doublers
Joseph Meyer
Philadelphia, PA
Offline 944_Jim
« Reply #2 on: March 21, 2019, 04:46:24 PM »
Just don't try to fix this one with nitrate over the butyrate...bleck! That'll.leave a mess.
Offline mccoy40
« Reply #3 on: March 22, 2019, 08:57:56 AM »
OK - so I'll sand the corners between the rudder and the doubler - then Tack them to get the dust off - then I'll wipe them off with some thinner - sound good ? oh - all butyrate
Joseph Meyer
Philadelphia, PA
Offline mccoy40
« Reply #4 on: March 25, 2019, 11:20:52 AM »
So I was thinking - if I cover the joints with an iron on covering - the one from Phil Cartier - that may also solve the issue
I'll try it and let you know what happens and how it looks
 #^    n~
Joseph Meyer
Philadelphia, PA
« Reply #5 on: March 30, 2019, 10:04:38 PM »
MC,
I think you need to start as Ty suggested by first sanding down the bubbles and get it smooth. Then hit it with primer sand smooth. Then do a coat of two to clear butyrate Sig lite coat (this is non-shrink). Then go to color with Sig butyrate (this is also non-shrink). In hard corners I use fillets (fuse/wing joints, stab/fuse, rudder/fuse. I like micro balloons and finishing resin mixed very thick.
Best,   DennisT
Offline mccoy40
« Reply #6 on: April 01, 2019, 11:27:19 AM »
Dennis,
I've started down the path Ty suggested. I was just thinking aloud what might work as an alternative -   n~   :!
Mccoy40
Joseph Meyer
Philadelphia, PA
