  • June 17, 2025, 06:54:41 AM
Author Topic: NITRATE THINNER  (Read 1833 times)
Online doug coursey
NITRATE THINNER
« on: April 15, 2023, 09:57:32 AM »
HAS ANYBODY USED BUTYRATE THINNER IN NITRATE DOPE....SEEMS LIKE IT SHOULD WORK SINCE YOUR PUTTING BUTYRATE DOPE WITH BUTYRATE THINNER OVER NITRATE DOPE....DOUG
AMA 21449
Offline Ty Marcucci
Re: NITRATE THINNER
« Reply #1 on: April 15, 2023, 12:15:19 PM »
Yes, but NOT the other way around.  As you know there is Nitrate thinner for strictly Nitrate dopes.. But Butyrate thinner will work as well. I do this all the time with NO problems. H^^
Ty Marcucci
Online doug coursey
Re: NITRATE THINNER
« Reply #2 on: April 15, 2023, 02:32:24 PM »
THE REASON IN ASKING IS I BOUGHT 2 QUARTS OF NON TAUTING NITRATE INSTEAD OF BUTYRATE SO I WAS GOING TO USE IT FOR THE FIRST  COATS OF CLEAR BEFORE I APPLY SILK AND ATTACH IT WITH THE NITRATE THEN USE BUTYRATE FOR SHRINKING AND FINISHING...
AMA 21449
Re: NITRATE THINNER
« Reply #3 on: April 15, 2023, 05:35:10 PM »
That’s going to work fine.
Online doug coursey
Re: NITRATE THINNER
« Reply #4 on: April 17, 2023, 06:15:41 AM »
IM GOING TO TRY IT ON A COMBAT PLANE WITH SILK...THE ONLY NEGATIVE THING I HEARD WAS FROM WINDY WHO SAID SUPER GLUE DOESNT LIKE TO STICK TO IT...SO HE QUIT USING IT..GOING TO USE 3 COATS ON WOOD BEFORE APPLING SILK THEN USE BUTYRATE  AFTER THAT
« Last Edit: April 17, 2023, 06:56:35 AM by doug coursey »
AMA 21449
