Building Tips and technical articles. => Paint and finishing => Topic started by: doug coursey on April 15, 2023, 09:57:32 AM
HAS ANYBODY USED BUTYRATE THINNER IN NITRATE DOPE....SEEMS LIKE IT SHOULD WORK SINCE YOUR PUTTING BUTYRATE DOPE WITH BUTYRATE THINNER OVER NITRATE DOPE....DOUG
Yes, but NOT the other way around. As you know there is Nitrate thinner for strictly Nitrate dopes.. But Butyrate thinner will work as well. I do this all the time with NO problems. H^^
THE REASON IN ASKING IS I BOUGHT 2 QUARTS OF NON TAUTING NITRATE INSTEAD OF BUTYRATE SO I WAS GOING TO USE IT FOR THE FIRST COATS OF CLEAR BEFORE I APPLY SILK AND ATTACH IT WITH THE NITRATE THEN USE BUTYRATE FOR SHRINKING AND FINISHING...
That’s going to work fine.
IM GOING TO TRY IT ON A COMBAT PLANE WITH SILK...THE ONLY NEGATIVE THING I HEARD WAS FROM WINDY WHO SAID SUPER GLUE DOESNT LIKE TO STICK TO IT...SO HE QUIT USING IT..GOING TO USE 3 COATS ON WOOD BEFORE APPLING SILK THEN USE BUTYRATE AFTER THAT
