  • July 17, 2025, 08:39:01 PM
Author Topic: Polyspan fuzz  (Read 1197 times)
Offline tom brightbill
Polyspan fuzz
« on: November 21, 2013, 07:11:13 PM »
I found that prior to final clear coats areas of fuzz can be mostly removed by using caution and a new #11 Exacto blade.  Shave them off by tilting the blade and shaving quite lightly from many different directions, being patient to make many passes. It has taken some practice.  Of course, it's obviously best to not get yourself into the situation to begin with.  Good luck.
AMA 34849
Offline Gerald Arana
Re: Polyspan fuzz
« Reply #1 on: November 21, 2013, 07:57:53 PM »
Hi Tom,
I agree with you! I use a straight edge razor blade for the same thing. Don't ask me why I did that! LOL!
Hope I see at a contest one day.
Later, GA
Online Howard Rush
Re: Polyspan fuzz
« Reply #2 on: November 21, 2013, 08:00:15 PM »
Reminds me of a gorilla joke.
Give the fuzzies a toot of clear and sand them with 1000 grit sandpaper-- a tip from Pete Peterson.
Re: Polyspan fuzz
« Reply #3 on: November 21, 2013, 09:02:28 PM »
 Yep, you can usually save it if you put a little extra clear on the fuzzies, let it dry thoroughly, and then work it down carefully with some superfine.
