  • July 16, 2025, 10:17:08 PM
Author Topic: New trick??  (Read 1705 times)
Offline Ty Marcucci
New trick??
« on: August 09, 2011, 03:38:28 PM »
 H^^
« Last Edit: March 18, 2017, 12:11:19 PM by Ty Marcucci »
Ty Marcucci
Re: New trick??
« Reply #1 on: August 09, 2011, 04:05:10 PM »
Somebody tell us what brands to use.  Some are much more susceptible to fading from sunlight(UV).
Re: New trick??
« Reply #2 on: August 09, 2011, 05:22:21 PM »
I don't use marker pens, but I do use India ink for all my blacks, including checkerboards.  It won't fade, can be easy to apply or a pain in the ...well...you know the rest.  I keep alchy close at hand at all times for the goofs I don't get with water right away.  But...all the possible goofs notwithstanding, it's still much easier to do after a little practice than taping and painting.  The clear goes over it fine, and it's the lightest weight black possible.
The reason I shy away from marker pens is that some of the "black" markers actually look green in the sunlight.  Because of that, the question of what brands is quite valid.
Online wwwarbird
Re: New trick??
« Reply #3 on: August 14, 2011, 08:46:46 PM »
 Got any photos of this Ty?
Re: New trick??
« Reply #4 on: August 15, 2011, 07:20:19 AM »
You're right, Ty - the markers are a lot quicker, easier, and don't have the propensity to be as messy, (spell that, fewer mistakes)
I wish I could remember the brand I found several years ago that were actually BLACK!!  I should have written the name down, but you know how that goes.  Thing is, there must still be some out there.  Maybe that would be a good research task for some of us?
Blessings,
Will
Re: New trick??
« Reply #5 on: August 15, 2011, 12:57:11 PM »
Ty    The large profile I sold you about 5 years ago that had the red and black checked leading edge was black marker. mw~
Re: New trick??
« Reply #6 on: August 27, 2011, 08:06:03 AM »
Here's a photo for you Wayne.
   Those particular markers have a remarkable smell, as well. It's gotta be bad for you, but after a few whiffs, you don't care.
