  • July 21, 2025, 03:30:47 AM
Author Topic: Neon Paint  (Read 2749 times)
Offline kevin king
Neon Paint
« on: September 07, 2022, 10:16:15 AM »
Its been awhile since ive sprayed neon Paint. Can anyone recommend a good product?
Kevin
Offline doug coursey
Re: Neon Paint
« Reply #1 on: September 07, 2022, 10:46:17 AM »
Kevin
SEM makes concentrate you can mix with clear
AMA 21449
Re: Neon Paint
« Reply #2 on: September 07, 2022, 12:57:17 PM »
Murray Howell has the lowdown.
Offline kevin king
Re: Neon Paint
« Reply #3 on: September 07, 2022, 05:14:08 PM »
Offline kevin king
Re: Neon Paint
« Reply #4 on: September 07, 2022, 05:18:28 PM »
Hi Howard, is Murray on SH or how do i contact him?
kevin
Re: Neon Paint
« Reply #5 on: September 07, 2022, 06:34:22 PM »
For what type of paint, urethane ?
it will mix with most any type of paint except enamel....i used it in clear dope,i also painted my helicopter canopies using 2 part sickens.. put it in some clear then used a white base coat and sprayed the floursent color over that.   I then applied the clear top coat clear.  we use 30% nitro and it was fully fuel proof...Doug
https://www.bing.com/search?pc=CBHS&ptag=N7312D103120AAA0D337D47&form=CONBDF&conlogo=CT2174808&q=sem+fluorescent+concentrate
https://www.ebay.com/itm/120943557712?chn=ps&norover=1&mkevt=1&mkrid=711-213727-13078-0&mkcid=2&itemid=120943557712&targetid=4580359295528871&device=c&mktype=&googleloc=&poi=&ca
AMA 21449
Re: Neon Paint
« Reply #6 on: September 07, 2022, 07:16:08 PM »
I don’t think I have a contact for Murray. I was hoping that one of his homies would provide one.
One problem I’ve noticed with fluorescent paint is that the color fades in the sun. Then if you put a UV-protecting clearcoat on it, it won’t fluoresce.
Offline 944_Jim
Re: Neon Paint
« Reply #7 on: September 07, 2022, 09:07:52 PM »
Wowzers, Kevin!
I fly on a lot ringed by trees 2/3rds around. I doubt I could lose THAT plane in the tree line. I don't care how long the paint lasts, since it would outlive any plane I fly anyway. I'll be watching for where this topic goes because I never considered florescent colors for my airplane palette.
Offline kevin king
Re: Neon Paint
« Reply #8 on: September 08, 2022, 08:48:52 AM »
@ Jim, I only know of 2 flyers that   used neon paints. Paul Walker and Steve Buso. Steve used the acrylic lacquer based Pactra neons that are for Rc lexan car bodies, andwith a 2 part Acrylic Urethane top coat. Both these paints are discontinued
Online Steve Helmick
Re: Neon Paint
« Reply #9 on: September 14, 2022, 06:39:39 PM »
kevin
Pretty sure Murray is on the ACFC FB page occasionally. That means you can look him up on FB and send him a message...I think! I don't really understand very well how FB works. Bruce P. should be able to send you an email address, so that should be another option.  H^^ Steve
Online Craig Beswick
Re: Neon Paint
« Reply #10 on: September 14, 2022, 07:47:46 PM »
You can search, "Murray Howell", on facebook.
AUS 87123
"The Ninja"
