  • June 29, 2025, 02:14:09 AM
Author Topic: Naptha (Lighter Fluid) to Clean  (Read 7096 times)
Offline Colin McRae
  • Are we having fun yet??
« on: September 04, 2024, 10:22:59 AM »
I'm recovering a wing on an old balsa model. It looks to me that the old covering might be Towerkote. When peeling off the old covering, the clear mylar comes off, but in a few places the glue and pigment stay behind. I tried naphtha (lighter fluid) in a test area, and it does remove the pigment and glue and expose the balsa wood with a little effort.
My question is if using lighter fluid to clean and prepare the affected areas, will the use of lighter fluid prevent the new iron-on covering from properly adhering. And are there any other useful tips? I plan to recover the wing with Monocoat.
How much time to allow the lighter fluid to fully evaporate?
Lighty sand the affected areas as a final step?
Etc.
Thanks in advance
Re: Naptha (Lighter Fluid) to Clean
« Reply #1 on: September 04, 2024, 11:09:08 AM »
I understand that pure naphtha does fully evaporate and does not leave a residue.   Personally, I would give the area a coat of ModPodge before recovering just to be sure.
