  • July 17, 2025, 05:09:22 AM
Author Topic: Mylar choice overload  (Read 1448 times)
Offline Angelo Smyth
« on: January 10, 2020, 10:05:16 AM »
OK. So I'm wanting to get away from doing monokote finishes and try the combination mylar / polyspan route. I've done a couple of searches about combination coverings (Mylar either over or under more traditional model coverings such as silkspan or polyspan) and it's advantages. There seems to be a load of information about how to apply the coverings, but I've not found what or where to get the Mylar.
A quick Amazon search turns-up a plethora of Mylar choices: 2mil, 6 mil, .003, .005, .007, .010 "Dura-Lar", iridescent, clear, gold, blue, metallic. Heck, even mylar bubble-wrap! (Having crashed more than a few planes last year, this may not be a bad idea  :!. Can you imagine flying a Ringmaster wrapped in bubble wrap  LL~.)
What exactly do you use and who sells this Mylar?
Thanks in advance.
-A.
Offline George Truett
Re: Mylar choice overload
« Reply #1 on: January 10, 2020, 10:20:32 AM »
« Reply #2 on: January 10, 2020, 12:22:40 PM »
Look for:    day_trader  on the Ebay.    Or search  Clear Super Flite Top Mylar Model Covering.    It has worked for me.  Some of of finished models are in the finish section. D>K
Offline Fredvon4
  • Central Texas
« Reply #3 on: January 10, 2020, 12:45:31 PM »
Forget the SLC in any quantity....Phil lost his supplier and is still searching for a similar replacement film
Drop down to Combat section and look for the Bob Mears posts for one tough and light method
The merits Larryy Renger schooled us to were Light poly/silk span...covered with a film instead of heavier dope made a composite covering stronge that eithr alone....many of us tried it....works the treat
Fred von Gortler IV
« Reply #4 on: January 10, 2020, 12:58:55 PM »
Weights of Mylar are like any other material, it depends on thickness.   All I know is it is lighter than and easier than silk span an dope. D>K
« Reply #5 on: January 13, 2020, 05:29:57 AM »
Awesome - thanks! I put some on order.
-A.
Online Ara Dedekian
  • Ara Dedekian
« Reply #6 on: January 13, 2020, 06:59:22 AM »
How thick is SLC?
According to my fancy digital vernier caliper, .0010".
Ara
Offline Fredvon4
  • Central Texas
« Reply #7 on: January 13, 2020, 09:42:30 AM »
I recommended a indoor aircraft vendor to Phil that had 1.5 mil film ...Phil told me he saw it, but it was 2x as heavy as SLC ----so I assume SLC is 0.75 mil...no backing film and if you ever used it (SLC) probably easiest one I used for compound tight curves.....
Fred von Gortler IV
« Reply #8 on: January 13, 2020, 03:28:20 PM »
   1.5 mil is *way* too much for indoor. I think on the heavier classes they used .25 mil. We used to use it for model rocket parachutes and flex-wing gliders - I would still really like to get *large* sheets of aluminized 1/4 mil, but I haven't been able to find it in wide rolls for many decades.
   The lightest indoor films are some plastic they use for the dielectric in capacitors, which I think is lighter than any version of microfilm. They don't make condenser paper any more, "condenser" being an obsolete term for capacitor, which are no longer made with paper/oil dielectrics.
