  • August 02, 2025, 10:59:40 AM
Author Topic: plastic covering over fiberglass  (Read 1953 times)
Offline Bootlegger
« on: January 20, 2017, 06:00:23 PM »
   How do you do this,  how well did it work?
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Jim Oliver
Re: plastic covering over fiberglass
« Reply #1 on: January 20, 2017, 08:37:22 PM »
Gil,
I have applied iron on over fiber glass with success but there are some cautions........
Use as little heat as possible so as not to warp the glass part or to soften the resin, also if you get the iron on covering too hot it will gas off badly and cause lots of bubbles between the glass and covering.  The gas has no place to go unless you prick the covering:(
Then the problem of sealing the edges........
Not sure exactly what you project involves but you must seal the edges of the covering to keep fuel etc. from creeping under the covering since it's almost impossible to get the covering to follow the weave of the glass, if any weave is visible.
Have fun:)
Jim Oliver
AMA 18475
Offline Bootlegger
« Reply #2 on: January 21, 2017, 07:12:50 AM »
 Sure do thank you for the reply Jim, I am planning to fiberglass the center section of the wing for strength, and then try to learn how to cover it with a plastic film.
 Again thanks...
Gil Causey
AMA# 6964
Offline Jim Oliver
« Reply #3 on: January 21, 2017, 07:14:46 AM »
That should be pretty easy.......let us know how it works out.
Which iron on are you using?
Jim Oliver
AMA 18475
Offline fred cesquim
    • Fred Cesquim Aeromodelos
« Reply #4 on: January 23, 2017, 05:51:18 AM »
i have done several times on the R/C planes
first you better use resin finish, sand with 320 grit and completely vaccum
seal the edge of the covering as Jim told, low heat, but enough to anchor firmly
then, the best way to bond it properly is to use a heat gun and a soft cloth do press it over while the glue is active. i never use the sealing iron to seal over sheeted surface, only to seal the perimeter of the covering and then taut everything with the heat gun.
