  • July 20, 2025, 02:07:34 AM
Author Topic: Monokote wing windows  (Read 1886 times)
Offline Dane Martin
  • heli pilot BHOR
« on: November 15, 2016, 10:15:19 AM »
These are old pics. But due to recent inquiries, I will put these out there in the event it helps someone.
Ok, I did some digging. My pics might not be excellent. And they're kinda small, but you'll get the idea. It is basically the same idea. The difference is the over lap. You want a lot! Lol.
So I make card board templates of what shape I want the window to be. Then I take that same template, and make it about 3/8 bigger around the entire border. The bigger piece is the clear template.
The reason for the big overlap is that is in the middle of the wing. It will be stretched from all directions. This is where it's important to put the covering on tight by hand, and the shrinkage with heat is minimal. That's the only hard part to doing these. The separation caused by stretching.
Notice I ironed this window in. Trim solvent is just as reliable in this application! When done correctly, either heat or trim solvent activate the adhesive equally. The solvent is a little easier to keep the lines straight, as there is no shrinkage. IF you iron, use the lowest heat possible to activate the adhesive. Pull test BEFORE you try to apply to a wing. If you can pull it apart, it will come apart on the wing!
Do the "corners" first. Apply a corner to the LE near the fuse. Then the TE, while pulling tight. Then about center of the LE. Then the LE wingtip. Then pull tight at centre of TE. Then TE wingtip. Then work the LE entirely. The TE is now pretty easy, just keep it tight.
Offline Dane Martin
  • heli pilot BHOR
Re: Monokote wing windows
« Reply #1 on: November 15, 2016, 10:18:03 AM »
More pics. This one had a black LE, so that was applied before applying to the wing also
« Reply #2 on: November 15, 2016, 01:28:34 PM »
"Great" Dane,
Wow! Always raising the bar.  H^^
Charles
