  • June 16, 2025, 12:26:58 PM
Author Topic: Which yellows with age, dope or urethane?  (Read 949 times)
Offline frank mccune
« on: December 20, 2019, 03:50:43 PM »
        Anybody have information regarding the above question?  Is there another product that will not yellow as a final finish?
        Tia,
        Frank McCune
Re: Which yellows with age, dope or urethane?
« Reply #1 on: December 20, 2019, 06:15:41 PM »
   Car clear does not yellow significantly with time.
Offline Alan Resinger
« Reply #2 on: December 26, 2019, 06:38:48 AM »
If you plan on using dope, Certified clear is by far the least likely to yellow with age.  I switched from Randolpg to Certified for that reason.
« Reply #3 on: December 31, 2019, 12:28:12 PM »
Absolutely, especially the 2 part clears with the hardener.
At the age most of us are at, you'll be dead before this clear yellows. LL~
