  • July 20, 2025, 01:44:57 AM
Author Topic: Monokote on Flaps  (Read 3311 times)
Monokote on Flaps
« on: December 14, 2016, 07:46:43 PM »
Is there a trick to putting monokote on flaps without warping them. I cover one side and the flap bends to that side then I cover the other side and try to shrink it just right to straighten it out. Thinking of just painting them, what do you do?
Re: Monokote on Flaps
« Reply #1 on: December 14, 2016, 08:14:09 PM »
It may be the heat bending the balsa as much as the Monokote tugging on it.
I never Monokote flaps, just prime, sand and paint. My thinking is that makes them stiffer. And I'll probably dope some carbon veil on the flaps for the wing I'm building now, hopefully adding more stiffness. I've never been a fan of Monokoting any solid surface, only my wings. I have 'koted a stab, but don't recall it fighting me like you're getting.
Rusty
Offline Target
  • C/L Addict
« Reply #2 on: December 14, 2016, 10:30:55 PM »
I think you should try to use the least heat possible on sheet surfaces, and get them covered completely at low heat...that should help avoid warping them.
Chris
AMA 5956
« Reply #3 on: December 15, 2016, 12:43:21 AM »
Seal, hit with the heat gun, straighten as necessary.  No problem.
Offline Phil Krankowski
« Reply #4 on: December 18, 2016, 07:39:46 AM »
I do this for thin elevators and it seems to work fine:
Size the film and put a crease in it glue side in.
Peal the protective layer.
seal only the leading edge in the crease.
trim to suit the bottom trailing edge, pull hand tight, and seal the TE and sides.
trim to suit the top TE and seal the TE but NOT the sides.  (the surface should be flat)
Seal to the wood and shrink from the middle to the ends, the open ends should let the extra air out.  A couple pinholes can be used to aid where it will be covered when the top is sealed.
seal the ends on the top (which should end up with the seam on the bottom)
Phil
« Reply #5 on: December 18, 2016, 08:50:56 AM »
Get the Top flite Woodpecker Tool,  part # lxhz26.   It put little holes in the wood as well as skin if not careful.
« Reply #6 on: December 18, 2016, 05:38:10 PM »
Doc, don't you dare run with that pecker in your hand!
Phil's idea with the open ends sounds pretty good.
Whenever I do have to pinhole a bubble, I use a new Exacto blade. Works much better than a pin.
« Reply #7 on: December 19, 2016, 01:58:08 PM »
Now you guys know that iron on covering isn't my thing, although years ago I did use it on a few R/C models. Years ago.
So, I pulled all the covering off of the ARF Spitfire wings I'm using for the GBR-3 and I noticed there was a million pin holes in the wood.
Now I remember a tool that was offered by some vendor that did this pin hole making thing easy.
Do you guys pin hole the balsa surface? Is it to let trapped air out?
Charles
« Reply #8 on: December 19, 2016, 08:16:29 PM »
...Do you guys pin hole the balsa surface? Is it to let trapped air out?
Charles
Yes, Charles, and that is why. It's done with the tool called a "Woodpecker" Doc was talking about in his post above.
Rusty
