  • July 21, 2025, 02:54:31 AM
Author Topic: Mixing Dope and thinner of diffrent brands  (Read 2472 times)
Offline Leonard Bourel
« on: April 22, 2021, 12:40:05 PM »
Just a quick Question  Can I mix Brodak Dope thinner with Sig Color dope?
Offline Bootlegger
Re: Mixing Dope and thinner of diffrent brands
« Reply #1 on: April 22, 2021, 03:50:16 PM »
 Just a suggestion, mix 1 ounce of each and that way you dont make an OOOOPPPPPPPPPPPPss
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #2 on: April 23, 2021, 06:27:39 PM »
Thanks guys I will try a small sample as suggested
Offline Jerry Rauch
« Reply #3 on: April 25, 2021, 08:27:19 AM »
I use Randolph Butyrate thinner in Sig Butyrate dope, works fine, and sometimes add a little Certified retarder when the humidity is above 50%, have had NO problems.
Offline Windwalker
« Reply #4 on: June 20, 2021, 07:12:46 PM »
I've done that on several occasions without a problem.. Quite often Sig is out of thinner and many colors or now not stocked, so I "experimented" a while back.
Nick Gans aka
Windwalker
Offline Perry Rose
« Reply #5 on: July 28, 2021, 12:06:29 PM »
I've been using Kleen Strip lacquer thinner in Randolph/Brodak butyrate dope without a problem. $17.00/gallon at Wal Mart. Sometimes I combine Brodak butyrate thinner and Kleen Strip thinner with Randolph retarder and butyrate dope, still no problems.
