  • July 18, 2025, 12:35:13 AM
Author Topic: Minado Day 26 fillets  (Read 2226 times)
Offline RC Storick
« on: July 26, 2014, 11:32:01 AM »
Superfill application
Check back in a few minutes
Eric Viglione
Re: Minado Day 26 fillets
« Reply #1 on: July 26, 2014, 02:44:21 PM »
Wow Sparky, I forgot how much work it was until I saw you doing it. Man, have I got a deal for you that will make your day! (well, a day in the future for you anyway)
I haven't done fillets like you showed in years. Keep using the Superfil and mix per usual... but FIRST...go buy a few of THESE:
http://www.amazon.com/Monoject-Curved-412-Syringes-5pcs/dp/B007Y8230G
Cut the tip back until the opening is a around 1/8" or whatever you find works for you with experience after you try it the first time.
Grab a Popsicle stick and trowel the superfil into the syringe, only takes a second to load it up.
Use the syringe to lay in a near perfect fillet like you are caulking your bathtub. You will have all 8 fillets done in the time it took you to do the one on video, and you won't have to tape it off once you get good at it, I don't tape them off anymore. Same finger/alcohol treatment to finish off.
If it isn't ten times easier I'll buy you a beer, heck, even an imported one.
Leave the unused superfil in the syringe overnight and let it cure hard. It will come out easy as a plug when you pull the plunger. I've used the same syringe on the last few planes, but I still bought a few to have on hand just in case.
EricV
Offline RC Storick
« Reply #2 on: July 26, 2014, 03:19:14 PM »
EricV
Looks like that would work. As I sated in my video I do everything like 1950 but I will give those a try. Thanks
Every time I watch someone fillet a model, I thank the good folks that clued me in on leather fillets!
I have that old stuff around here some where if I ever run across it ,its yours.
Offline RC Storick
« Reply #3 on: July 26, 2014, 04:08:00 PM »
Its been a while sense I tried to do a top notch finish and I have forgotten how much sanding is involved. I will be awhile at this sanding business.
Offline Gerald Arana
« Reply #4 on: July 26, 2014, 05:30:08 PM »
Sparky,
Being cheaper than you. LL~ LL~, I use plane old water to do the job you do with 95% alcohol. Works great. (For me)
I gotta get me some of that DC 540. That looks like the ticket to a fast finish.
Tight lines, Jerry
Eric Viglione
« Reply #5 on: July 26, 2014, 05:47:45 PM »
Oh, BTW... I don't know if you do internal wing/fuse and stab fillets, but I do. I use the syringe to do nice tiny internal fillets, much smaller than the external fillets. I do them like 1/2" long spot welds, not continuous beads. Adds almost no weight, simpler and lighter than other things I used to do like putting strips of carbon or glass L-brackets, or balsa strips, and adds tremendous strength to your wing and stab joint.
Since some piped planes have a wide open bottom tunnel, I fillet some of the more exposed formers too, especially that last 1/2" near the cowl seam of F-1 & F-2, it seems to help a lot with the separation that can happen there over time. (especially if you get a little ham fisted and overly aggressive jamming in a tank shim,  HB~> )
EricV
Offline RC Storick
« Reply #6 on: July 26, 2014, 06:14:13 PM »
I do internal fillets the demo is in my videos
