  • July 12, 2025, 05:21:24 PM
Author Topic: Microfiber cloths as tac rags?  (Read 1415 times)
Offline Brian Massey
    • California Car Clubs
« on: July 21, 2009, 04:34:15 PM »
Any one know if microfiber cloths work as a tac rag?  :! They seem to pick up everything, but not sure about this application. Seems to me they should, but then I've been wrong before.
Brian
AMA 55421
Madera, CA
Offline Ralph Wenzel (d)
Re: Microfiber cloths as tac rags?
« Reply #1 on: July 21, 2009, 09:36:30 PM »
If it's a used one, you should probably wash it first. Give it a shot - What can it hurt?
Ralph Wenzel
AMA 495785 League City, TX
« Reply #2 on: July 22, 2009, 10:18:37 AM »
I would be hesitant becuase they can pick up a static charge and transfer lint and other contaminants to the surface you are painting. Real tack rags are much less expensive and much more effective for the job. Why reinvent the wheel, use the microfiber cloths for polishing, use tack rags for tacking off before you paint
Offline Robert McHam
« Reply #3 on: July 22, 2009, 03:16:01 PM »
NO. Use the tack rags!
While the microfiber cloths are good at what they do, so too are the tack rags.
The tack rag has a resin stickiness that the microfiber cloths do not. Mark is right. Use the microfiber cloth but the last thing to touch the surface to be painted before the paint itself should be a tack rag.
Robert
« Reply #4 on: July 24, 2009, 03:43:49 PM »
Thanks for the info; I'll be picking up some tack rags.
Brian
AMA 55421
Madera, CA
