  • June 15, 2025, 10:29:34 AM
Author Topic: CLEAR COAT  (Read 2474 times)
Offline Greg L Bahrman
CLEAR COAT
« on: May 30, 2023, 10:15:56 PM »
Can I safely put SIG clear over BRODAK colors ?
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline doug coursey
Re: CLEAR COAT
« Reply #1 on: May 31, 2023, 02:32:56 AM »
yes im doing it now on the plane in building..i used sig clear super coat to tighten the silk covering and put brodak black over it..i also put brodak crystal clear over the sig
AMA 21449
Offline Miotch
Re: CLEAR COAT
« Reply #2 on: June 01, 2023, 12:40:47 PM »
I've put SIG over Brodak and Brodak over SIG and the dope never knew the difference.  I recently shot some old SIG dope using lacquer thinner from Home Depot that worked beautifully.  I was actually a bit surprised, but it thinned and shot wonderfully.
Re: CLEAR COAT
« Reply #3 on: June 01, 2023, 02:58:18 PM »
BRODAK DOPE IS NON-TAUTINING SO IT DOESNT SHRINK COVERING REAL GOOD..THATS WHY I USED SIG SUPER COAT  TO SHRINK THE SILK ON MINE VERSES THE BRODAK CLEAR
« Last Edit: June 02, 2023, 09:28:28 AM by doug coursey »
AMA 21449
Offline kevin king
Re: CLEAR COAT
« Reply #4 on: June 02, 2023, 02:50:06 PM »
Sig Lite Coat yes. Sig clear Supercoat, only if you dont mind warped structures.
