  • July 12, 2025, 06:52:47 AM
Author Topic: Metallic Paint Additive  (Read 2195 times)
Offline Harold Brewer
« on: May 07, 2021, 09:17:17 AM »
I'm getting ready to paint my latest project (Fierce Arrow 875),  The paint I am going to use needs something to jazz it up.  Are there any metallic powders that can be added to the paint to add some "glisten" to the apperance or give it a metallic look?
Regards.
Harold
Re: Metallic Paint Additive
« Reply #1 on: May 07, 2021, 12:12:40 PM »
Regards.
Harold
Yes, there's plenty of that stuff, do a search on line.
Keep in mind, you'll be adding weight and will probably need a fuel proof clear coat.
They already have metallic paints.
Another thing, depending on the size of the "flakes," you may  need a special tip for your spray gun.
Offline George Truett
« Reply #2 on: May 07, 2021, 01:00:13 PM »
Here is one of the companies selling it:  https://usa.hemway.com/collections/automotive  I used to use the same type product from PPG years ago, it took several heavy clear coats on top before you could polish it.
Offline Steve Berry
« Reply #3 on: May 07, 2021, 04:25:43 PM »
Keep in mind that, per Windy (and probably many others, too), if you spray metal flakes, you better have a dedicated gun beforehand, because you'll certainly have one later. Apparently the stuff never gets completely cleaned out of the gun. Same principle behind a dedicated clear gun that never sprays colors.
« Reply #4 on: May 07, 2021, 07:59:14 PM »
 Yep, excellent advice.  y1
« Reply #5 on: May 09, 2021, 03:42:40 PM »
 I painter a lot of models in the 1960-70’s by adding silver to the color. I did one Juno  about 15 years ago and it came out super metallic.
« Reply #6 on: May 09, 2021, 08:20:04 PM »
   The silver trick is pretty effective. And I'll mention that there is a difference between metallic and metal flake. Adding metal flake to stunt model finish may not look "right" to you because the flake may be too big. Adding just some silver or even gold pigment to your color or clear may give you a more subtle effect for a model. There was a guy from Iowa that we used to see at the SIG contest, Sam Scirota (may be mis-spelling the last name) and he did custom car paint jobs for a living and did this effect well. Sometimes he used ground glass and it looked awesome but almost impossible to use that and keep the finish light. When I left my last job to retire, I brought home some additive that they would put in ink for silk screening shirts for a metallic effect. It was a tall container, maybe a quart or so, and was as light as micro balloons.  They were getting ready to close up operations and I was clearing out and pitching anything that wasn't going to be sold off, so I was able to bring it home. There is next to nothing on the label so I have no idea exactly what it is, but it's plenty sparkly!! I'll try that on something some day soon I hope.
