  • July 20, 2025, 02:55:07 PM
Author Topic: Magic Eraser - OR - PTG is pretty smart  (Read 1351 times)
« on: June 02, 2020, 09:14:04 PM »
Last time I painted a serious airplane (2006...) Phil Granderson gave me a great bit of advice. Mr Clean "Magic Eraser" pads are AMAZING for cleaning up pencil lines, light overspray and generally brightening up your paint job while you are working on it. Phil credits the lovely Kathleen, but I doubt that Kathleen has spent a lot of time erasing pencil lines from model airplanes.
   The best thing about it is that it is so soft and takes such little pressure, that there is nearly no chance of damaging anything in the attempt. The one to use is the original, non-scented Magic Eraser, and use just water to dampen it and squeeze it out, then just rub the offending area. It will conform and clean a pencil line right up to the paint edge. Also, very light overspray. When it starts turning colors, rinse it out, and go again. It will abrade away pretty quickly, then get a new one.
Offline Mike Griffin
Re: Magic Eraser - OR - PTG is pretty smart
« Reply #1 on: June 02, 2020, 09:57:47 PM »
Thank you for the tip Brett.  Linda uses them all  the time.  I will swipe one from  under the cabinet and abscond with it before she misses it.
« Reply #2 on: June 03, 2020, 11:18:47 AM »
Great idea. I usually just use an soft eraser, but I'll try this.
Online Robert Whitley
« Reply #3 on: June 03, 2020, 11:59:30 AM »
Another great use for them is streak free highly effective cleaning of automobile interior windshields and other glass.
« Reply #4 on: June 03, 2020, 12:06:08 PM »
   This is MUCH safer, even a very soft eraser can leave a dent.
« Reply #5 on: June 03, 2020, 12:31:56 PM »
Brett,
Exactly. Thanks for the tip.
Offline Matt Colan
« Reply #6 on: June 03, 2020, 07:53:29 PM »
I’ve been using the magic eraser for years and I 100% agree with Bretts statement. It’s so easy to use and very forgiving. I have learned that removing heavier pieces of overspray, over time, the magic eraser starts to erase some of the base coat as well, but it takes a long time to get to that point
