  • July 05, 2025, 08:13:32 PM
Author Topic: Rustoleum on 'coat  (Read 1233 times)
Rustoleum on 'coat
« on: November 15, 2011, 10:56:07 PM »
So, I wanna squirt some Rustoleum trim onto some Ultracoat.
My understanding is that I just rough up the Ultracoat where I want the Rustoleum to stick -- I have some nice fine brass wool that should do an outstanding job for that.
But how do I rough up the Ultracoat where the Rustoleum will stick, without roughing it up outside of where the Rustoleum will stick and thereby leaving unsightly blemishes?  I can't imagine trying to mask and then rough things up.  Or is there some way of polishing out the scratches from the brass wool?
While I'm at it -- how do I mask things off so the Rustoleum won't bleed under the tape?  The usual prescription I hear is to paint clear on the tape edge -- but what to use for clear?
Offline Russell Shaffer
Re: Rustoleum on 'coat
« Reply #1 on: November 16, 2011, 08:47:52 AM »
I taped and then roughed to the tape.  But I'm no craftsman.
Russell Shaffer
Klamath Falls, Oregon
« Reply #2 on: November 16, 2011, 10:03:54 AM »
Tim, mask it, then rough it up.
I cannot vouch for the mechanical bond that you will get with ultracote and rustoleum,,
The other way,, what I would likely do,,
mask your trim outline with 1/8 or 1/4" fine-line or other masking tape,, then mask outside that tape with another 1/4"  ( depending on the turn radius you may need to use 1/8")
scuff the crap out of the ultracote inside the masked edge,,
pull up the original tape, and re-mask using the second line of mask for a guide( this will insure you get back where you started, and have scuffed ultrakote where you want it)
spray away,,
oh and make darn sure to clean the ultracote with alcohol, then wax and grease remover, then soap and water before you mask. mold releasing type agents can be very tenacious.
If you have cleaned the surface properly,, laid the tape properly,, not exceeded the bend radius of the tape, and apply your paint properly, you should not have any bleed issues,,
and of COURSE we know this effort isnt going into the worlds second most labor intensive Arf flight streak, ( Dirty Dan has the MOST labor intensive flight streak as I recall)
« Reply #3 on: November 16, 2011, 10:30:33 AM »
Why, of course not, Mark.  It's not labor intensive, it's joy intensive!!
Good point.  We had a soon-to-be-formerly trusted employee in the late 70s who got PO'd at my dad and wiped down a part of a car body mold with acetone.  While the bond was good enough to severely damage the mold, it was far from 100%.  So, yes -- lots-o-cleaning.
Offline John Hammonds
« Reply #4 on: November 17, 2011, 06:55:19 AM »
Hi Tim,
  I don't know if it would do the job, but in the UK Solarfilm ( http://www.solarfilm.co.uk/ ) market a product called "Prymol" (Presumably similar products are available from other suppliers). It's basically an "Etch Primer" which can be used to increase the adhesion of paint to iron on films and also to provide a stronger fuel proof joint where film surfaces overlap. I have used it on solarfilm products and it certainly works although being electric fuel contamination was not a concern.
TTFN
John.
BMFA 165249
Mike Griffin
« Reply #5 on: November 20, 2011, 12:34:53 PM »
I know that Allen Brickhaus has been painting plastic film coverings for years and tells me that he has never roughed up the surface he is going to paint.  He has planes that are years old and has had no flaking or peeling of the Rustoleum.  I very rarely ever use plastic films but I am just passing on something that a great builder in our hobby has told me.
« Reply #6 on: November 20, 2011, 01:50:20 PM »
I just re-read Allen Brickhaus's Finishing the Olympus in Flying Models.  He makes no mention of prepping the film surface, although if I'm reading things right he's telling you to peel off the tape when the paint is wet, or at least not fully dried (!?!).
This calls for a test piece...
