  • July 13, 2025, 11:49:07 AM
Author Topic: lusterkote over silkspan  (Read 1004 times)
Offline frank j. scire
« on: June 08, 2010, 12:51:04 AM »
 hows it going guys. I had realy bad results with trying to monokote the wings.So if I use silkspan, once the wing is complete can I use lusterkote primer and color. Over the silkspan.
Re: lusterkote over silkspan
« Reply #1 on: June 08, 2010, 01:42:28 PM »
provided you fill the silkspan with dope or something then yes - Lustrekote it pretty easy to put over most things
Offline Leester
« Reply #2 on: June 08, 2010, 08:11:18 PM »
Several precautions though, shake well then shake again. Lustre kote will run easily so light coats work best and NO DOPE OVER Lustre Kote.
Leester
ama 830538
« Reply #3 on: June 08, 2010, 09:18:47 PM »
thanks guys,your help is much appreciated.
