Building Tips and technical articles. => Paint and finishing => Topic started by: frank j. scire on June 08, 2010, 12:51:04 AM
hows it going guys. I had realy bad results with trying to monokote the wings.So if I use silkspan, once the wing is complete can I use lusterkote primer and color. Over the silkspan.
provided you fill the silkspan with dope or something then yes - Lustrekote it pretty easy to put over most things
Several precautions though, shake well then shake again. Lustre kote will run easily so light coats work best and NO DOPE OVER Lustre Kote.
thanks guys,your help is much appreciated.
