  • July 18, 2025, 12:36:34 AM
Author Topic: Look at this  (Read 2277 times)
Look at this
« on: June 28, 2014, 03:13:33 PM »
In case you didn't  catch this in the main forum here are some ideas for doing something different.
http://stunthanger.com/smf/index.php/topic,35698.0.html
Ed n~ n~
Re: Look at this
« Reply #1 on: June 29, 2014, 03:28:21 PM »
Man that clear coat looks good!
Derek
Re: Look at this
« Reply #2 on: June 29, 2014, 05:48:50 PM »
Derek   The spray cans may be lacquer. I noticed it said to clean up with Lacquer thinner and it dried very fast. If it is Lacquer then dope will go over it. Some times clear dope does odd thing to semi clear colors. It needs white under it to come out true. Notice how parts of the yellow look like green. I used grey primer under all the color except where the yellow meets the red on the wing and there the yellow looks like yellow. The plane gained 2.25 oz with primer, color, and the clear coat.
Ed >:D ;D
Re: Look at this
« Reply #3 on: June 29, 2014, 09:23:57 PM »
I liked Paul Walker's neon paint. Of course, what was supposed to have been red and yellow ended up as pink and chartreuse, but it looked cool anyway.
Offline Bootlegger
Re: Look at this
« Reply #4 on: September 09, 2014, 10:33:10 AM »
Eddy I sent ya' a P/M   thanks, Bootlegger
8th Air Force Veteran
Gil Causey
AMA# 6964
