  • June 18, 2025, 01:38:47 AM
Author Topic: KBS Clear weight--one coat  (Read 2626 times)
Offline bruce finley
« on: November 25, 2014, 07:20:04 AM »
FYI
Just applied one medium foam brushed coat of KBS on my Gotcha Streak--48" 520 sq's-- and added 1.2 oz.  Pretty much slopped it on, it did level out very nicely.  I covered the entire model surface.  Man it stinks!! :X Yes I did wear a mask.
Re: KBS Clear weight--one coat
« Reply #1 on: December 07, 2014, 04:42:19 PM »
Bruce,
Good information. It would be interesting if someone does one sprayed to see the difference. My guess is that if you add about 35% reducer you could spray it from a cheap Preval spray bottle (about $6). If sprayed maybe it would be about 3/4 oz?
Best,    DennisT
« Reply #2 on: December 10, 2014, 10:36:18 PM »
Bruce,
Best,    DennisT
I dunno, Dennis. The Gotcha Streak is pretty small. You could probably get the weight down a little by spraying, but on a 40-60 size stunter, I'm afraid of what even one sprayed coat weighs. Guess maybe similar to urethane clear?
« Reply #3 on: December 11, 2014, 10:04:06 AM »
Is this the amount you sprayed on or the weight after it cured?   Dope loses weight as it cures by the evaporation of materials.   Water base paints lose a little while curing by evaporation.   I know the two part auto clear I usually mix up two to three ounces for spraying and on my Gotcha Streak I had to mix up more to finish.  But, if you can get a high gloss finish clear and still be in the ball park for finish, why worry? S?P
