  • July 17, 2025, 07:29:56 PM
Author Topic: lacquer retarder  (Read 1259 times)
Offline Bootlegger
lacquer retarder
« on: September 24, 2013, 10:00:23 AM »
 Folks I am looking for some lacquer retarder that will work in dope. I have used Startex brand in the past, and it works, have you used another brand, if so where did you get it, and how did you like it?
           Thanks a lot
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: lacquer retarder
« Reply #1 on: September 24, 2013, 12:19:37 PM »
Sorry, Gil, I can't help you Gil.  :'(  I have only used Sig Retarder...............
BIG Bear
RNMM/AMM
Offline billbyles
« Reply #2 on: September 24, 2013, 01:05:57 PM »
           Thanks a lot
Gil,
For both model airplanes & full-scale airplanes I use Randolph Products butyrate retarder.  I have also used with equally good results Sig retarder.  I'm curious why you are looking for another brand...
Bill Byles
AMA 20913
So. Cal.
Offline Bootlegger
« Reply #3 on: September 24, 2013, 01:29:25 PM »
  Bill B the reason that I used Startex is availability, and the fact that it works in dope as well as lacquer o paints.
  I've not used Sig brand, but if I did it would have to be ordered. Startex was picked up in a paint store in the Baton Rouge, La. area and I don't live too far away, so it is somewhat local.
  Thanks for the help...
Gil Causey
AMA# 6964
