  • June 29, 2025, 02:42:21 PM
Author Topic: K&S Silk  (Read 1372 times)
Offline Gary Anderson
K&S Silk
« on: May 12, 2009, 01:03:49 PM »
Has anyone used this product? Does this material need washing before its installed on the wing?  Is this material installed the same way as silkspan? I have read Brian's post, and I believe the same method would apply. Would appreciate your input, Gary
Gary Anderson
Offline Larry Renger
Re: K&S Silk
« Reply #1 on: May 12, 2009, 02:12:34 PM »
Definitely do not wash the silk.  K&S is the old style shrinking type.  It shrinks nicely after the first wetting.  It can be applied dry, then water shrunk like Japanese tissue or applied wet.  If you do apply wet, you better have a strong structure!  It has been known to collapse stick and tissue free-flight models.
Once it has been wet and shrunk the first time, it only expands slightly when wetted and then returns to previous state.
RSM sells silk that is the more recent type.  You wet it, apply it as tight as you can, and then you are OK.  It expands slightly when wet, then shrinks back to the previous size.  If you buy his silk, READ THE DIRECTIONS!!!!  It works just fine if you do.
Re: K&S Silk
« Reply #2 on: May 12, 2009, 02:38:11 PM »
Exactly what Larry said. If you do use the newer silk, use high shrink dope for the first few coats.
