  • June 17, 2025, 04:10:46 AM
Author Topic: Clear over old dope & maybe wax.  (Read 1039 times)
« on: April 20, 2019, 03:46:56 PM »
I got a plane from a friend (not the Atlantis, which I know to be clear-coated).  It had some serious hanger rash, which required patching some ripped silkspan.
I want to spot in clear over the repairs, but I don't know if the plane has been waxed.
Is there a good reliable way of removing wax from dope that doesn't remove the dope, too?
Offline Dave Royer
Re: Clear over old dope & maybe wax.
« Reply #1 on: April 20, 2019, 05:25:24 PM »
Prep sol then windex.
Offline Mike Haverly
« Reply #2 on: April 20, 2019, 07:09:25 PM »
Naptha, works great and much less expensive than Prepsol.
Offline Phil Krankowski
« Reply #3 on: April 21, 2019, 07:17:06 PM »
Ammonia strips wax.  Floor wax, automotive wax, crayon and candle wax, doesn't matter too much.  Silicone based coatings are another story, and I don't know how to remove those.
A gallon of grocery store ammonia is some $2.  Dillute in warm water, apply, let sit a few minutes, wipe off.  When satisfied rinse with water.  Allowing overnight to dry is probably a good idea too.  I would use several clean rags for each step and not too wet.
I would still test but I am pretty confident that dope is unaffected by ammonia.
Phil
« Reply #4 on: April 21, 2019, 08:16:34 PM »
If you use Ammonia make sure have plenty of fresh air. D>K
