  • August 05, 2025, 05:28:59 AM
Author Topic: Ultrapoxy bye K&B  (Read 1944 times)
Offline Gary Anderson
Ultrapoxy bye K&B
« on: April 11, 2009, 10:43:51 AM »
Hi guys,
I've used K&B Epoxy paint years ago, is this the same product? Didn't K&B quit making this product years ago? Can you thin the ultrapoxy with DuPont 3608s? If this paint is as good as the old K&B Epoxy paint it should be great. With the old K&B one coat and you was good to go. Would appreciate any input. I typed in search and there was a short article but was wondering if anyone else has played with this paint, Gary
Gary Anderson
Offline Pinecone
Re: Ultrapoxy bye K&B
« Reply #1 on: April 12, 2009, 09:07:52 AM »
AFAIK the older SuperPoxy and the newer UltraPoxy are different.
KlassKote says their hardener will work with SuperPoxy, but not UltraPoxy.
MECOA bought the rights to teh K&B line.  IIRC, they have some UltraPoxy, but are selling off the stock and there will be no more.
There is KlassKote and Nelson Hobbies epoxy paints.
The Nelson stuff is water-based, and a System Three base product.
Terry Carraway
AMA 47402
« Reply #2 on: April 13, 2009, 10:20:41 PM »
Hi guys,
     K&B Ultrapoxy was pretty good stuff, but its definitely on the way out, as far as I can tell. Klasskote is a superior and far more available replacement, and that's what I use now.
