  • July 18, 2025, 09:16:41 PM
Author Topic: KlassKote Clear Urethane  (Read 1829 times)
Mike Griffin
« on: October 11, 2014, 09:04:25 PM »
I have never used this product.  I was wondering if you could use it over enamel and acrylic lacquer base coats.
Also do you need to thin it pretty good and can you brush it or does it need to be sprayed?
I know nothing about the product so any input would be appreciated.
Re: KlassKote Clear Urethane
« Reply #1 on: October 12, 2014, 10:40:17 PM »
I thought the Klass Kote stuff was all epoxy?
What happened with that Diamond Finish Clear stuff? I thought that sounded very promising, and was hoping for more information, such as weight increase, fuel resistance and spraying.
http://www.kbs-coatings.com/DiamondFinish-Clear.html
 H^^ Steve
Mike Griffin
« Reply #2 on: October 13, 2014, 05:37:09 PM »
Steve,
KlassKote does make a two part urethane clear.  I have found all urethane clears I have used in the past to go  over any basecoat without any adverse effects But I have never used this product.
The KBS works great but I have not recorded before and after weights.  The next ship I do, I will make note of that.
