  • June 15, 2025, 02:49:15 PM
Author Topic: Clear dope stored in metal cans goes dark amber?  (Read 1164 times)
« on: September 11, 2020, 06:10:20 PM »
I have a question for the group about clear dope that has been stored for some time in sealed metal cans going dark amber in color. The dope seems to work fine, flows out nice and dries solid. I had some other dope from this same batch that I had in a glass jar that sat on the shelf just about the same amount of time and it is only straw colored. Both were about 7yrs old. Anybody come across this with clear dope? Could the cans be reacting with the dope giving that darker color (almost like it kinda rusted and dissolved into the dope?
Best,    DennisT
Offline kevin king
Re: Clear dope stored in metal cans goes dark amber?
« Reply #1 on: September 11, 2020, 10:16:30 PM »
I can only say I've never had an issue with Sig Light Coat turning rust. The other brand I have is rust colored.  But I can always use that for building up the substrate before the color, then never buy it again.
« Last Edit: September 15, 2020, 10:19:29 AM by kevin king »
« Reply #2 on: September 12, 2020, 09:53:11 AM »
Best,    DennisT
     It sounds like you decanted it from a larger container? If so it may be the can you put it in. I think they treat the inside of the can with some kind of coating to prevent the can from rusting and that may be what you see?
Offline Norm Furutani
« Reply #3 on: September 13, 2020, 11:30:41 AM »
I’m pretty sure its rust. It gets worse in partially full cans (more air). Once a can is opened, I store the remainder in glass jars with PTFE seals (McMaster Carr). Tried HDPE jars/bottles and they crack over time.
NormF - 60+ years, sniffing dope
