  • June 15, 2025, 09:36:57 AM
Author Topic: Best Masking Film for Vinyl Cutters  (Read 1651 times)
Online frank williams
« on: February 09, 2022, 03:58:00 PM »
I'm looking for the best masking film to use in my cutter.  The stuff I've tried is Oramask 830s.  Its a grey vinyl.  It curls up when lacquer based paints hits it.
What should I buy that is compatible with our typical paints and is the right tack and thickness?
Offline George Truett
Re: Best Masking Film for Vinyl Cutters
« Reply #1 on: February 09, 2022, 04:35:59 PM »
I've had good luck with Avery 3090 White removable vinyl paint mask.
« Reply #2 on: February 09, 2022, 05:31:27 PM »
Thanks George ... I'll give it a try
Offline Larry Wong
« Reply #3 on: February 09, 2022, 07:49:22 PM »
.  you need  810S solvent mask  y1
Larry
Offline kevin king
« Reply #4 on: February 10, 2022, 12:51:11 AM »
Oramask 813 worked very well for me. And don't forget good ol' MacTac either, Its called MACmask, really good for curved surfaces.
Kevin.
« Reply #5 on: February 10, 2022, 07:26:03 AM »
I was incorrect .... what I have is 810s ...... and I don't like it ... sorry Larry
