  • June 16, 2025, 07:12:02 PM
Author Topic: Rustoleum 2X Clear...  (Read 1454 times)
Dwayne
« on: April 22, 2019, 04:59:40 PM »
...Is not fuel proof. That is all.  HB~> :'(
Re: Rustoleum 2X Clear...
« Reply #1 on: April 22, 2019, 05:23:09 PM »
   WHERE HAVE YOU BEEN!!!!..  Sometimes the best lessons are the hardest learned, but it's great for sand paper sales! y1 y1 This post needs to be pinned to the top of the forum!!!
Dwayne
« Reply #2 on: April 22, 2019, 06:31:10 PM »
Luckily the effected areas cleaned up pretty quick with a lot of rubbing with alcohol, will pick up some Spray Max 2K and life goes on.   ::) n~
« Reply #3 on: April 22, 2019, 08:43:19 PM »
Any reason not to use it on an electric?
Offline Chancey Chorney
« Reply #4 on: April 22, 2019, 08:59:55 PM »
I guess I should coat the parts I sprayed a couple days ago with 2X with something fuelproof then?  ;D Ran out of Minwax, so thought I would give the 2X a try. Well, it looks like I am off to epoxy the firewall now.
Dwayne
« Reply #5 on: April 23, 2019, 05:16:06 AM »
No, you can use anything you want on a electric.  y1
« Reply #6 on: April 23, 2019, 08:38:33 AM »
y1 y1
