  • June 16, 2025, 11:19:03 PM
Author Topic: Bondo  (Read 2004 times)
Bondo
« on: December 13, 2018, 04:36:30 PM »
I am about to make my first stab at using Bondo Fiberglass Resin. ~^  Is there anything I need to know that is not on the can?  Realistically, how soon can I sand it and will MonoKote stick?  Any pre-treatment for carbon fiber veil? Search was not much help.  Maybe someone has a link to a video or something. :!
Thanks - Ken
Re: Bondo
« Reply #1 on: December 13, 2018, 10:31:22 PM »
If you're meaning Bondo auto body putty...I'd say very emphatically: DON'T! It's heavy and not a good match to the hardness of balsa, so sanding will become a problem. Personally, I don't like anything based on polyester resin and opt for epoxy stuff. Epoxy has less smell, longer working time, longer shelf life, more reliable, etc.   H^^ Steve
Re: Bondo
« Reply #2 on: December 13, 2018, 11:02:24 PM »
Nope, it is the fiberglass resin.
Offline Don Jenkins
Re: Bondo
« Reply #3 on: December 14, 2018, 06:27:46 AM »
I've only used fiberglass resin with Micro-balloons for making fillets, and drying/curing time depends on how much activator is added, usually an hour or two.  When it's no longer tacky it's ready to sand.  I've only used it with an epoxy paint finish, so I don't know how it works with other finish materials.
Don
Offline Alan Resinger
Re: Bondo
« Reply #4 on: December 14, 2018, 07:18:48 AM »
Ken,
Fiberglass resin is either polyester or vinylester resin.  Not sure what you are doing but sounds like you are getting ready to finish a model and are trying to prep the wood nefore covering and finishing.   I would highly reccomend using epoxy finishinf resin for the job.  Zap makes a good epoxy finishing resin that a lot of top flyers and finishrs use.  Stay away from polyester resins inless you are finishing boats.
Re: Bondo
« Reply #5 on: December 14, 2018, 09:07:51 AM »
I would also echo Alans recommendation to use Zap Zpoxy it's just a joy to work with. That being said I think the usual way to stick down CF vail is to paint on 2 coats of 50/50 nitrate then brush the vail down with thinner. With polyester resin I've never had any luck getting the right amount of hardener to control the pot life. Usually sets up way too quick and sometimes it cures gummy. YMMV
Motorman 8)
Would lacquer work in place of nitrate?   Part of the reason to go electric was to eliminate dope from finishing.  My wife is allergic to the smell.  She can handle Lacquer, which is actually worse smelling...go figure.
Offline pmackenzie
  • Pat MacKenzie
Re: Bondo
« Reply #6 on: December 15, 2018, 07:09:07 AM »
Bondo/polyester resin smell is horrible, much worse than dope.
Try a sample using MINWAX water based poylurethane. I know it works well with glass cloth or silkspan.
Good description of non-dope finishing here:
http://www.flystunt.com/2014/01/28/a-modern-model-finish/
MAAC 8177
