  • June 23, 2025, 05:16:55 PM
Author Topic: New trick??  (Read 1652 times)
Offline Ty Marcucci
New trick??
« on: August 09, 2011, 03:38:28 PM »
 H^^
« Last Edit: March 18, 2017, 12:11:19 PM by Ty Marcucci »
Ty Marcucci
Re: New trick??
« Reply #1 on: August 09, 2011, 04:05:10 PM »
Somebody tell us what brands to use.  Some are much more susceptible to fading from sunlight(UV).
Re: New trick??
« Reply #2 on: August 09, 2011, 05:22:21 PM »
I don't use marker pens, but I do use India ink for all my blacks, including checkerboards.  It won't fade, can be easy to apply or a pain in the ...well...you know the rest.  I keep alchy close at hand at all times for the goofs I don't get with water right away.  But...all the possible goofs notwithstanding, it's still much easier to do after a little practice than taping and painting.  The clear goes over it fine, and it's the lightest weight black possible.
The reason I shy away from marker pens is that some of the "black" markers actually look green in the sunlight.  Because of that, the question of what brands is quite valid.
Re: New trick??
« Reply #3 on: August 14, 2011, 08:46:46 PM »
 Got any photos of this Ty?
Re: New trick??
« Reply #4 on: August 15, 2011, 07:20:19 AM »
You're right, Ty - the markers are a lot quicker, easier, and don't have the propensity to be as messy, (spell that, fewer mistakes)
I wish I could remember the brand I found several years ago that were actually BLACK!!  I should have written the name down, but you know how that goes.  Thing is, there must still be some out there.  Maybe that would be a good research task for some of us?
Blessings,
Will
Re: New trick??
« Reply #5 on: August 15, 2011, 12:57:11 PM »
Ty    The large profile I sold you about 5 years ago that had the red and black checked leading edge was black marker. mw~
Re: New trick??
« Reply #6 on: August 27, 2011, 08:06:03 AM »
Here's a photo for you Wayne.
   Those particular markers have a remarkable smell, as well. It's gotta be bad for you, but after a few whiffs, you don't care.
