  • June 17, 2025, 03:14:19 AM
Author Topic: Silk  (Read 2165 times)
Silk
« on: August 14, 2018, 11:00:53 AM »
Where's the best place to get silk fabric to cover a plane? I have a small project I'd like to do in silk.
Re: Silk
« Reply #1 on: August 14, 2018, 11:04:53 AM »
Get your wife a nice silk scarf, and steal a couple of feet of it.
Re: Silk
« Reply #2 on: August 14, 2018, 11:37:42 AM »
Randy,
Here's the link to the Vendor I use. I tried a few.
http://www.dharmatrading.com/fabric/silk/silk-habotai-5mm.html
Really nice silk.
Charles
Offline Tom Luciano
Re: Silk
« Reply #3 on: August 14, 2018, 11:48:38 AM »
Randy,
  As Charles suggested and I've had very good luck with Thai silks. I've been using their 4.5mm "paj" with good results. I've had good results with Rit dye as well.
Tom
AMA 13001
Offline Fredvon4
  • Central Texas
Re: Silk
« Reply #4 on: August 14, 2018, 12:30:25 PM »
There are several sources... I personally prefer Dharma
I highly recommend going to the Dharma site and reading all their help and description areas
Momme MM as in 5MM or 8MM is a weight and weave standard...8MM is a tighter and heavier weave than 5MM
That said, I have yards of both the slightly lighter (per yard) 5 MM....but seems to me, to need a tad MORE dope to fill than the heavier 8MM so final finish weight is about the same within a few grams...this is just my opinion based on how I determine final fill and glossy
Note: the 5MM stuff can be bought cheap and white...almost all the 8MM stuff is colored.... Dharma has excellent series of how to's on all their different dye methods
Since for me, there is no reason to stick with 5MM white and then the expense of time and cost for dyes...My opinion is to not worry about 8MM being heavier  if they have a color that fits your final color scheme
As much as I would love to support the Cottage Guys their silk is way too expensive....Thai or Dharma have plenty of stock in all sorts of colors well under $5 per yard
ONE hint
Thai or Dharma silk shrinks 1 to 2% in width and 6 to 7% in length...DO NOT BUY a 1 yard/36" by 1 yard/36" SQUARE  piece...near impossible to determine length vs width....suck it up and just buy two yards...easy, still cheap, done, and no problem NOW knowing how to cut it for the wing panel....
Hint #2...today's silks do NOT shrink as much as the 1950~1970s stuff and a lot of it NOW has sizing chems added...
SO pay attention to orientation
Pre wash/rinse in clear hot water...no soap
Let dry if later project... as drying--- stretch it in both directions
DO NOT apply the silk sloppy wet...just barley damp and stretch as you go doping down the perimeter
Use Butryate Tautening for the initial first two or three fill layers then switch to NON Tautening
Fred von Gortler IV
Re: Silk
« Reply #5 on: August 14, 2018, 04:08:23 PM »
Thanks. I haven't used silk in many moons, though I did a lot of planes in silk back in the day. Thanks for the links and advice.
Offline Fredvon4
  • Central Texas
Re: Silk
« Reply #6 on: August 16, 2018, 02:18:31 PM »
Just to emphasis... I said it before and Ty just mentioned it.... every MFG sells silk with some form of SIZING agent
and the singular propose it to make cutting and packaging easier and faster.... silk is a very slippery material and damned hard to fold into small mailer packages
SO again: order enough to know for certain Length vs width
Just before use or before storage...rinse and rinse and rinse again in hot water only...no soap
I recommend continual stretching as it dries but not that critical
Every failure I had was trying to use the stuff as delivered...grin quite a bit of waste because I never asked the right questions and did NOT read the web site FAQs on CHINA SILK....
Fred von Gortler IV
Re: Silk
« Reply #7 on: August 22, 2018, 04:52:57 PM »
Thanks, guys
Re: Silk
« Reply #8 on: August 24, 2018, 09:22:59 PM »
 Randy, check your PM.
Re: Silk
« Reply #9 on: August 29, 2018, 04:10:44 PM »
Wayne,
Caught that but Ty came to my rescue.
